  Soarer Central * ICE - In Car Entertainment * ICE Chat * FUSTRATED Previous Previous    Next Next
Anthony Wah Day
W.A
Soarer GT V8
Tuesday, February 14, 2006 - 09:40 pm, by:  Anthony Wah Day (Naastee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys and gals,
The other day i found a thread about someone putting in bigger front speakers with pictures in the thread, and now i can't find it, does anyone have the link, MUST be the one with pics
Thanks
Anthony
Sam Schreck
vvt-i JZZ31
Tuesday, February 14, 2006 - 09:53 pm, by:  Sam Schreck (Schreck300) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This it?
http://soarercentral.com/sc-forum/messages/13208/42422.html#POST62687
Tuesday, February 14, 2006 - 09:54 pm, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think you are talking this thread here:
Changing size of front speakers in doors ??
Is under Soarer Central-->ICE - In Car Entertainment-->ICE Gold-->Changing size of front speakers in doors
http://soarercentral.com/sc-forum/messages/13208/42422.html?1139914688
Sam Schreck
vvt-i JZZ31
Tuesday, February 14, 2006 - 09:56 pm, by:  Sam Schreck (Schreck300) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So close, so close
Anthony Wah Day
W.A
Soarer GT V8
Tuesday, February 14, 2006 - 10:20 pm, by:  Anthony Wah Day (Naastee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry guys,
Both wrong, this one had a pic of the stock speaker then the empty bit then another pic witht the new speaker, the new speaker was red i think if that helps
Mark Paddick
Soarer UZZ31
Wednesday, February 15, 2006 - 01:05 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This is the easy way;
The ones shown will allow 4.5" to 5" speakers to fit. Larger speakers can be done by using one of the thin 4.5" spacers and a thin 5" or 6" spacer on top as long as the magnet will go through the smaller hole.
As long as the total thickness of the spacers is kept below about 20mm the door trim will still fit OK.
Sam Schreck
vvt-i JZZ31
Wednesday, February 15, 2006 - 01:07 pm, by:  Sam Schreck (Schreck300) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ryan Rankovic
Soarer TT GT-TL
Wednesday, February 15, 2006 - 11:01 pm, by:  Ryan Rankovic (Ryan1j) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
is this it?
i made those pics
http://soarercentral.com/sc-forum/messages/13208/30009.html?1133595862
Anthony Wah Day
W.A
Soarer GT V8
Thursday, February 16, 2006 - 01:32 pm, by:  Anthony Wah Day (Naastee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
WE HAVE A WINNER
thanks
Ryan
Leonie Eason
SOARER
Reg: 01-2007
Sunday, December 22, 2019 - 02:59 pm, by:  Leonie Eason (Leodoug) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Installed a new system plus rear speakers ( uvf damage ) by a auto electrician ...because the original radio only worked within sight of the radio station!, $1000 later the new radio works for anywhere between 5.... 15 minutes crackles a couple of time and stops . Can anyone make any suggestions as to why and how to fix. Electrician spent countless hours on this}
Justin Hughes
V8 Soarer
Tuesday, December 24, 2019 - 08:51 pm, by:  Justin Hughes (Juzza) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Id be running a new power cable from the battery (with fuse) to the unit.
Tom Richards
Thursday, December 26, 2019 - 08:33 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
when you say it stops, do all the lights go out just like it has been turned off?, or does it look turned on, but has no sound?
Tom Richards
Sunday, December 29, 2019 - 12:10 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
any response to above questions?
