  Soarer Central * ICE - In Car Entertainment * ICE Chat * Amp Placement Previous Previous    Next Next
Trevor Tai
Soarer GT-TL
Wednesday, March 08, 2006 - 05:33 pm, by:  Trevor Tai (Quiksilva) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys,
I was just wondering if the trim in the boot closest to the fuel tank was strong enough to hold a 10kgs worth of amps like Joe had in his?
Joe, if your still around, did you need to reinforce it?
Mark Paddick
Soarer UZZ31
Wednesday, March 08, 2006 - 05:48 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Absolutely not.
It's lucky to stand up on it's own
Wednesday, March 08, 2006 - 06:03 pm, by:  Daniel Czechowski (Dan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You do have to reinforce it, or it will fall apart in short time. I thought of doing it without any support, and it just seemed too wobbly to me, with all the bumps and stuff when you are driving it will get looser over time. So when I mounted my amp that way, put a piece of wood behind the lining, and then just screwed it together and now it holds nice and stiff.
Rob Andreacchio
UZZ31 V8 / JZZ30 TT
Reg: 01-2005
Wednesday, March 08, 2006 - 06:04 pm, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
spot on Daniel... i'll have the audio tutorials back up online hopefully this weekend :-)
Joshua Rowland
TT (Manual)
Wednesday, March 08, 2006 - 08:18 pm, by:  Joshua Rowland (Jnr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i have two Rockford Fosgate Amps on the back like Joe's, i just put a piece of mdf on the back of the trim and screwed the amps on that way,you dont see the wood on the back.
Thursday, March 09, 2006 - 12:31 pm, by:  Daniel Czechowski (Dan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Joshua Rowland wrote on Wednesday, March 08, 2006 - 08:18 pm:
How often do you pull the trim off and pose it for looks? Who cares if you see wood there or not, it's all a big mess behind there anyway
Trevor Tai
Soarer GT-TL
Thursday, March 09, 2006 - 01:35 pm, by:  Trevor Tai (Quiksilva) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks fellas...
but does the trim hold on tight enough? there is only 4 or 5 hooks/clips holding the trim in place, I would think a quick traffic light getaway would pull the trim off?
Rob Andreacchio
UZZ31 V8 / JZZ30 TT
Reg: 01-2005
Thursday, March 09, 2006 - 01:59 pm, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i used a few self tappers up top to hold it in place...
Trevor Tai
Soarer GT-TL
Thursday, March 09, 2006 - 08:07 pm, by:  Trevor Tai (Quiksilva) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hmmm... think i'll try making some brackets to hold the MDF board and trim against the fuel tank.
Thanks fellas, really helpful stuff!
