  Soarer Central * ICE - In Car Entertainment * ICE Chat * OK Mark I've had enough of this stereo - what about a package deal Previous Previous    Next Next
Open in new windowArchive through August 12, 2005Jason Parsloe16
Steve Patterson
2x V8 LTD's
Friday, August 12, 2005 - 08:28 pm, by:  Steve Patterson Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jason Parsloe wrote on Friday, August 12, 2005 - 08:13 pm:
what to spend my doe on those V8 headers or the A/V conversions
Power before prettiesUpload
Mark Paddick
Soarer UZZ31
Friday, August 12, 2005 - 10:43 pm, by:  Mark Paddick Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You'll LOVE the headers.
I didn't turn the stereo on or wind windows up for weeks
Found you email and replied Ian....jeez I get a lot of mail; it was buried in heaps of rubbish.
Todd Triebler
Saturday, August 13, 2005 - 06:57 am, by:  Todd Triebler Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rob, yeah I'm with you. But moving the face of the radio has obviously made enough room to fit the DVD player in. That's so much better than mounting one in the glovebox or the boot.
Todd Triebler
Saturday, August 13, 2005 - 07:01 am, by:  Todd Triebler Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Righto Mark so to summarise :
Radio Conversion $500
TV conversion $455
Total $955
Which bits do we need to rip out and send to you?
Pics needed for the noobs I'd say
Mark Paddick
Soarer UZZ31
Saturday, August 13, 2005 - 03:57 pm, by:  Mark Paddick Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Soarer radio with DSP on the left lives under the rear seat, passenger side ;
Tv tuner lives under drivers' side rear seat;
Mark Paddick
Soarer UZZ31
Saturday, August 13, 2005 - 04:30 pm, by:  Mark Paddick Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Most CD stackers can be repaired. The main problems with them are faulty lasers and loading mechanisms.
The lasers can usually be adjusted to work a bit better and play burnt CDs. The laser clean and adjust and re-alignment of tracking is normally $50 to $80.
About 10% will need a new laser. I can usually find a second hand laser for around $75.
I can also get new lasers which come with new spindle motor and suspension system; $340 fitted and aligned.
I would personally not recommend a new laser unless you have the later model stacker (which has to have the new style laser…there are three different factory fitted lasers).
I have seen a few stackers which have been fitted with new lasers and have killed them in less than 18 months. Hence I don’t trust the new ones.
Other faults like broken loading mechanisms can be fixed for around $100 to $150.
There are three main types of stacker for the Soarer.
1. Without EMV
2. With EMV
3. Late model non-EMV
The EMV and non-EMV stackers are NOT interchangeable.
The can be converted by changing the main board which then necessitates a re-alignment.
The later model non-EMV can be fitted in place of the early one (don’t know if revers is true). The main difference is that late models do not check all the discs before starting to play disc 1 when the cartridge is changed. They just go straight to the first slot with a CD and play it…much quicker to load.
The single CD in dash player uses exactly the same playing mechanism as the stacker so repair of them is essentially the same (except the laser is a lot harder to adjust easily).
Dimitri Argeres
SC400 (V8)
Friday, August 19, 2005 - 04:13 am, by:  Dimitri Argeres Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is there at tutorial somewhere to remove those two items, or is it simple??
cheers
Friday, August 19, 2005 - 09:31 am, by:  Daniel Lee Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dimitri,
Mark have the Radio tuner removal procedure and he can email that to you if you ask him :-)
Mark Paddick
Soarer UZZ31
Friday, August 19, 2005 - 10:04 pm, by:  Mark Paddick Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sent
Anthony Gasson (Zbfairlane)
Soarer V8
Saturday, August 27, 2005 - 08:52 pm, by:  Anthony Gasson (Zbfairlane) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
On this subject, I purchased the whole lot from mark a while ago, and it was delivered promptly. The whole kit, E-12 fix, tv mod, PAL-NTSC, reverse cam, and the fm tuner mod.
I completed the fm tuner mod today and the instructions are very good and easy to follow. I think this is an excellent mod to any V8 soarer, and wish I had done it before anything else, including my exhaust system.
Haven't done the fm mod? do it now...!
