Sunday, April 22, 2007 - 07:59 pm, by: Blake Gloyn(Blakenz)
brad, the 150,000km service requires the removal of the 2jzge engine,and the bolting of the 1jzgte head and the turbo/turbos of your choice onto it.a 3mm head gasket will reduce the compression to the correct level. refit the engine, and enjoy.yeah yeah yeah i know- no one loves you 2jzge owners... ;)
Monday, April 23, 2007 - 08:43 am, by: Bradley Parnell(Scrad)
Haha I read that first bit and thought you were going to say something like "Replace crankcase bearings" or something..
One of my plans-that-will-probably-never-happen-but-will-if-i-get-organised is to grab the 2JZ-GTE engine from an aristo with a 5 spd tiptronic and slap that in there..
Then i will have horsepowers as well.
But for now the 2JZ-GE will do me just fine. (It's probably keeping me alive, truth be known)
Monday, April 23, 2007 - 12:29 pm, by: Matthew Sharpe(Madmatt)
Add brake bleed in if you haven't had one recently. Plugs should still be OK as long as they were done at 100,000 - test leads, check distributor cap and button etc.
Monday, April 23, 2007 - 02:37 pm, by: Bradley Parnell(Scrad)
I had a look at the first spark plug and it looks fairly new + clean. How hard would it be to get them all out? I'm assuming you have to pull the throttle body off to get at all of them?
Tuesday, April 24, 2007 - 11:18 am, by: Matthew Sharpe(Madmatt)
Yup, but it's not as bad as it sounds, do a search and you'll find a tutorial I wrote on it - late last year I think it was... Took me an hour and a half or so, and that was with a fair bit of stuffing around. Also good chance to clean the throttle body.
