  Soarer Central * Mechanical - N/A 6 (JZZ31) * AT Fluid Previous Previous    Next Next
Bradley Parnell
JZZ31 N/A
Reg: 11-2006
Monday, April 30, 2007 - 10:38 pm, by:  Bradley Parnell (Scrad) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just wondering what we should use for the AT fluid..
I know there is write-ups galore about the V8 using type 4 and some TT's as well (with some being OK for Dexron), but I havent been able to find anything about the JZZ31 tranny..
So if I am planning to do an AT fluid change, what should I use?
Rob Andreacchio
Supercharged VT Calais & 1991 JZZ30
Reg: 01-2005
Monday, April 30, 2007 - 10:39 pm, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just stick with Type 4.. available from any toyota dealer..
Mustafa Akgul
JZZ30-GTTL
Monday, April 30, 2007 - 10:51 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I use castrol transmax z synthetic oil in my tt.(very expensive though)about $68 for 4 litres.:-)
Tuesday, May 01, 2007 - 07:05 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
JZZ3x's aren't fussy like UZZ3x's - any good quality Dexron III or higher will do.
Norfolk Island
Tuesday, May 01, 2007 - 12:50 pm, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Depends on which JZZ31 you have. Our '95 had Dexron II stamped on the dipstick (now Dex III, of course) while the '97 has Toyota IV. They are different gearboxes, so require different fluids. Go with the owner's manual or the dipstick.
Ellerslie
None
Tuesday, May 01, 2007 - 02:18 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hmmm how do your gearboxes differ in the 95 and 97 models Mike?
Norfolk Island
Friday, May 04, 2007 - 09:43 am, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The '97 is "intelligent" which I assume means adaptive. Don't know what the model numbers are though. I believe our gearbox was used in the Lexus GS300 right up to the end of the model run (2005) although could be wrong, they might have changed to 5-speed.
