Saturday, September 08, 2007 - 12:08 pm, by: Daniel Hogan(Bratwurst_boy)
hey guys, my girlfriend just bought a 96 jzz31, just wondering, if any, what problems to look out for. its got 115***kms on the clock and has just been recently imported from japan. thanks dan
Saturday, September 08, 2007 - 04:34 pm, by: Matthew Sharpe(Madmatt)
I bought my '96 two years ago at 85,000 km.
Since then I've done 50,000 km, and today I've finally hit my first problem - the v belt tensioner bearing is on its way out, so I'll replace it next week.
In 50,000km I've done the following service wise:
7 oil & filter changes 3 air filter changes 1 Timing belt replacement 1 V belt replacement 1 new set of Iridium spark plugs 1 new distributor cap 1 new distributor rotor 2 transmission services 2 brake fluid flushes 1 coolant flush 4 tyres
I think thats it. I guess technically the v belt bearing is a service part too, and it hasn't caused a break down.
Monday, September 10, 2007 - 08:11 pm, by: Daniel Hogan(Bratwurst_boy)
thanks guys, i'll keep an eye on that stuff. got another question, just wanted to know if we change the stock cd/sat nav/tv for an aftermarket headunit do we have to change all the speakers, sub and amp??
Tuesday, September 11, 2007 - 06:33 am, by: Matthew Sharpe(Madmatt)
You can keep your speakers no problem - amp I'm not too sure on - it doesnt use normal RCA connectors so you'd have to have a good idea what you were doing to wire it up I guess.
Wednesday, February 06, 2008 - 09:23 am, by: Daniel Hogan(Bratwurst_boy)
hey guys, just tried to book my jzz31 into Toyota in gympie (i no but its the closest one) for its 120k service, and the service guy is trying to tell me that they have a policy that they don't service import cars...WTF. anyway he said he would be able to do an oil and filter change (which i could do at home) it couldn't be that hard to find the parts needed to do the service, considering its Toyota.
that's enough of my rambling.
cheers
Mike Triggs Goo Roo Western Australia 3.0GT G-Pack
Wednesday, February 06, 2008 - 04:18 pm, by: Mike Triggs(Mikeandimah)
Daniel Hogan wrote on Wednesday, February 06, 2008 - 09:23 am:
Even more so considering how many other cars the motor is used in.
Find another dealer- if not, ask around for a competent mechanic.
What's required at 120k? The timing belt should have been done at 100k. I had the mechanic on Norfolk Island do most of the required stuff prior to leaving (including water pump- not that it really needed one) while diff etc oils I did myself. The only fluid I didn't change was the auto trans, for which I need to get to a trans specialist (and again, there isn't one locally).
Wednesday, February 06, 2008 - 07:11 pm, by: Daniel Hogan(Bratwurst_boy)
yeah, the guy i talked to in the service department had a know idea that the 2jz came out in the jza80 supra. i'm going to take it to an old family mechanic who serviced my bro jzz30.
