  Soarer Central * Mechanical - N/A 6 (JZZ31) * Squeaky Clutch Previous Previous    Next Next
Brian Kelly
Colorado USA
Reg: 04-2007
Tuesday, October 09, 2007 - 03:39 am, by:  Brian Kelly (Whereswaldo583) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi everyone. I recently got my clutch replaced with a Centerforce stage 1, and now every time the clutch pedal is released there is a squeaking/chirping noise coming from underneath the car. Any ideas? Thanks.
-Brian
Tuesday, October 09, 2007 - 05:48 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ease off on the throttle before releasing the clutch
No, seriously, just take it back to where you got it done and get them to sort it.
Jonathan Hong
California
JZZ31 (N/A 5 speed)
Reg: 10-2006
Wednesday, October 10, 2007 - 10:35 am, by:  Jonathan Hong (Djyoshi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had that problem 2 weeks ago. Opened it up, something was wrong/loose with the transmission shaft. Should get it checked out and fixed.
