  Soarer Central * Mechanical - N/A 6 (JZZ31) * 1jz into MX83 Cressida A340 Issue Previous Previous    Next Next
Daniel Brady
Glx with 1jzgte
Reg: 01-2010
Monday, January 04, 2010 - 02:09 pm, by:  Daniel Brady (Brady89) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi All'
I have just purchased a MX83 Cressida with a 1jz conversion out of a jzx81 and am having an issue with the Auto transmission only selecting 1st and Reverse.
When the conversion was first done it had a manual box in it and was running fine on the auto ecu, once the previous owner blew the box he changed it back to auto (auto was taken out of another cressida that previous owner had driven and he said it was driving fine) and since it has changed back to auto it will only select 1st and Reverse.
I am sure it will be something electrical but after looking around on the forums I just cant pin point what exactly is the issue. I have not tried another ecu as yet. Thinking maybe the Auto ecu was modified to run the Manual box and now that its back to running and auto again that could be the issue.
I am planning to take it to an auto electrician in the next few days to look into it.
Any advice or ideas as what it could be would be appreciated!!!!
Blake Gloyn
manawatu
soarer JZZ30 TT
Monday, January 04, 2010 - 06:55 pm, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
is it a cressida box or a jzx81 or soarer box.? reason i ask is that the cressidas had their own ECU for the trans.
