  Soarer Central * Group Buys * EOI chrome door pillars Previous Previous    Next Next
Warren Moore
JZZ31 N/A
Reg: 01-2010
Saturday, October 30, 2010 - 12:07 am, by:  Warren Moore (Warreng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Recently Masato sold a pair of these on the forums and it received great interest. I am also wanting a pair of these so I have decided to look into a group guy. I have been speaking to the seller in the US who sells these and he would be able to do them for around $60 AU each including postage for 20 pairs. Add your name to the list if you want in!
1. Warren Moore
Michael Larcombe
TAS
Soarer GT - TL
Reg: 08-2009
Saturday, October 30, 2010 - 12:50 am, by:  Michael Larcombe (Lextcy_tas) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is it the same seller who also sells carbon fibre ones or is that a different seller? I have seen them both on Ebay. Registering interest for carbon fibre pillars if it is possible through the same seller.
Beats wrapping pillars in di-noc I guess :-)
Ty Mackay
Soarer TT 1jz-gte
Reg: 01-2009
Saturday, October 30, 2010 - 11:27 am, by:  Ty Mackay (Duo89) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
like i keep saying theres a guy on soarercentral who makes them for half the price lol
Warren Moore
JZZ31 N/A
Reg: 01-2010
Saturday, October 30, 2010 - 02:52 pm, by:  Warren Moore (Warreng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Michael Larcombe wrote on Saturday, October 30, 2010 - 12:50 am:
The seller can get carbon pillars, but he explained that they are just 3M cutouts..
Jason Cheah
2JZGTE JZZ31
Saturday, October 30, 2010 - 09:43 pm, by:  Jason Cheah (Freaky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Has anyone managed to fit one of these without removing the wind deflectors?
Warren Moore
JZZ31 N/A
Reg: 01-2010
Saturday, October 30, 2010 - 09:48 pm, by:  Warren Moore (Warreng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jason, their flexible I think, their just a chrome adhesive.. I don't see why you would have any troubles
Jason Cheah
2JZGTE JZZ31
Saturday, October 30, 2010 - 10:15 pm, by:  Jason Cheah (Freaky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Warren,
I guess you don't have wind/rain deflectors installed on yours?
Look here.
Look at how the deflector attaches to the pillar and you will know why I ask the question.
I don't want to remove mine to install the cover as it will wreck the foam/seal of the deflector (most probably)
Warren Moore
JZZ31 N/A
Reg: 01-2010
Saturday, October 30, 2010 - 10:25 pm, by:  Warren Moore (Warreng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I guess the wind deflectors would have to be removed and re applied then.. im guessing it wouldn't be too hard of a job?
Ben Kelly
Lakemba
v8
Saturday, October 30, 2010 - 10:36 pm, by:  Ben Kelly (Ace) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
jason since yours are in perfect nick i dont reckon you should touch them at all.I reckon i would take a set except that isnt it reportedly quite easy to remove paint and polish up the underneath?
btw where did you get the deflector?
Jason Cheah
2JZGTE JZZ31
Saturday, October 30, 2010 - 10:37 pm, by:  Jason Cheah (Freaky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Probably. But not worth the trouble for me as new seals/3M double-tape(cut to fit) would have to done.
No time to muck around... Hahaha.
Warren Moore
JZZ31 N/A
Reg: 01-2010
Saturday, October 30, 2010 - 11:01 pm, by:  Warren Moore (Warreng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben Kelly wrote on Saturday, October 30, 2010 - 10:36 pm:
You mean like this?
http://www.clublexus.com/forums/gs-first-generation/368769-diy-polished-window-trim.html
I know you can do the window surrounds but not to sure about body trim. I know that with the door surrounds you need to polish the trim quite frequently or the shine starts to fade. You wont get any fade with these.
Jason Cheah
2JZGTE JZZ31
Sunday, October 31, 2010 - 01:31 pm, by:  Jason Cheah (Freaky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey ben. that pic was not my car. Mine's not too bad but wouldn't mind real carbon inserts. Deflectors came original with the car when I brought it over from japan.
Lynden Phillips
Soarer UZZ31
Reg: 05-2006
Sunday, October 31, 2010 - 06:35 pm, by:  Lynden Phillips (Malicia) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine were stainless steel, just hit them with some paint stripper and BAM all shiny.
