Sunday, October 23, 2005 - 10:26 pm, by: Steven Malkin(Soaring)
The hose itself is easy to install, but if you are not familiar with fitting and bleeding brake or clutch systems, we would recommend that it be carried out by any automotive repair shop. We do fit and bleed brake and clutch systems at our workshop in Drysdale, Geelong.
Tuesday, November 14, 2006 - 04:47 pm, by: Steven Malkin(Soaring)
It is the flexible hose that joins the steel tube from the body to the steel tube that goes into the slave cylinder. It is positioned on the lower left of the car about where the bellhousing is.
