Manufacturer: | Toyota |
Model: | Soarer Z30 series (JZZ30, JZZ31, UZZ30, UZZ31, UZZ32) |
Body: | 2 door |
Vehicle Weight: | 1560, 1540, 1590, 1640, 1730 kg |
Years of Manufacture: | 1991-2001 |
Place of Manufacture: | Japan |
Sold in Australia: | No |
Engine Type: | V8, Inline 6, Inline 6 Twin Turbo |
Engine Displacement: | 3968cc V8, 2997cc I6, 2492cc I6TT |
Bore/Stroke: | 87.5 x 82.5 mm (V8), 86.0 x 86.0 mm (I6), 86.0 x 71.5 mm (I6TT) |
Induction: | NA, NA, Twin turbocharged |
Transmission Type: | Auto, 5sp Manual |
Driving Wheels: | rear |
Standard Factory Wheel Size: | 16” x 7.0” (UZZ30 1991), 16” x 6.5” (JZZ30 1991) |
| 16” x 7.5” (UZZ30, JZZ30 2001) |
Standard Factory Tyre Size: | 225/55R16 (UZZ30), 215/60R15 (JZZ30) |
Brake Type Front/Rear: | Vented power assisted brakes |
296mm (front), 307mm (rear) (JZZ30, UZZ32) |
275mm (front), 290mm (rear) (UZZ30, UZZ31, JZZ31) |
Suspension Type Front: | Independent, double-wishbone, coil springs, gaspressurized shock absorbers, stabilizer bar. (UZZ30, JZZ31) |
Independent, double-wishbone, TEMS airbag springs, stabilizer bar.(UZZ31) |
Independent, double-wishbone, Active hydraulic. (UZZ32) |
Suspension Type Rear: | Independent, double-wishbone, coil springs, gaspressurized shock absorbers, strut rods, stabilizer bar. (UZZ30, JZZ31) |
Independent, double-wishbone, TEMS airbag springs, strut rods, stabilizer bar.(UZZ31) |
ABS Standard: | Yes |
Traction Control Standard: | No (option) |
Stability Control Standard: | Yes /No |
Homologation Type: | N/A |
Homologation Place: | N/A |
Homologation Date: | N/A |
Australian Registration No’s: | |
