  Soarer Central * Track and Major Rebuild Car Projects * Post Up Your Lap Times * Archive through July 17, 2012 Previous Previous    Next Next
Andrew McKellar
Soarer Sports Sedan (well, nearly); '84 MA61 Supra.
Reg: 06-2008
Sunday, March 21, 2010 - 12:15 am, by:  Andrew McKellar (Toymax) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Was thinking about putting this in General Discussion, but I think most of the real enthusiasts will look in this area instead.
I want to know what sort of lap times people are doing, at each of the major circuits around the country. I'm using this purely as a bench-marking process for my car, so there are a few rules before you think about putting your times up:
1. No wankers. I need genuine, fair dinkum lap times, and this is not a thread for you to stroke your own ego.
2. Soarers only. It's not relevant what time you managed to put down in nana's Daihatsu Charade. As I said, this is a bench-marking exercise, and I want to try and compare apples with apples. I know there are different varieties of apples (read: different models of Soarers), but I don't need oranges here.
3. I need some basic info about your car. No need for a novel or a full specification list. Just tell me what engine, briefly outline mods (just saying "Suspension Upgrade" or "Big Brakes" will be enough), auto or manual transmission, how much weight has been pulled out, and what tyres you were running (again, I don't need brands, sizes or anything, just say slicks, semi-slicks or whatever).
4. It is not a pissing contest. I'm looking for the fastest lap times you have done, but read through the thread first. If your time at a particular circuit is slower that what someone else has put up, you won't help much by putting your time up, unless your car is a different setup. I am interested in seeing times from cars with different levels of modification.
Oran Park is dead and gone, but if you want to throw some times up for it still, go right ahead.
So, let's hear them then.
Cheers,
Andrew
Sunday, March 21, 2010 - 06:27 am, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mallala, 1:30:?? - UZZ30, auto with cat-back exhaust, TT brakes, semi slicks and empty boot.
Andrew McKellar
Reg: 06-2008
Sunday, March 21, 2010 - 07:59 pm, by:  Andrew McKellar (Toymax) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for getting the party started Peter.
Ben Lipman
Sunday, March 21, 2010 - 09:41 pm, by:  Ben Lipman (Ben12a) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wakefield Park 1:09.99
Oran Park Sth 51.22
Oran Park GP 1:24.82
Hidden Valley 1:25.1
Details in my track car thread. Way faster than Andrew's sports sedan
Andrew McKellar
Reg: 06-2008
Sunday, March 21, 2010 - 11:31 pm, by:  Andrew McKellar (Toymax) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Technically correct, seeing as though mine is still on the axle stands. But if the speed of the starter motor is anything to go by...
Why didn't you do anything at Eastern Creek before you moved north? A bit scared were you?
Ali Saeed
Sunday, March 21, 2010 - 11:56 pm, by:  Ali Saeed (Ali) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i wish we had a good track. barbagello doesnt let people on the full thing apparently.
Ryan McDonough
STOCK JZZ30 TT
Monday, March 22, 2010 - 07:28 pm, by:  Ryan McDonough (Ryan) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wakefield Park 1:25.?? Stock lowered springs, TT pov no LSD street tyres. Also before the resurface.
Ben Lipman
Tuesday, March 23, 2010 - 09:11 am, by:  Ben Lipman (Ben12a) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Andrew McKellar wrote on Sunday, March 21, 2010 - 11:31 pm:
Yes, but your Soarer will NEVER beat my Oran Park time...
Yeah, turn one gives me nightmares. Nah, I just could never get a track day and my availability to line up. I guess when they charge a billion dollars to hire the track and then you have to to share it with eleventy other car clubs and corporate groups no one can be bothered with it. Gonna have to now though.
I'll get there one day. I think I'll try and hit every permanent circuit in Australia...
Andrew McKellar
Reg: 06-2008
Tuesday, March 23, 2010 - 12:15 pm, by:  Andrew McKellar (Toymax) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for your input Ryan.
Ben Lipman wrote on Tuesday, March 23, 2010 - 09:11 am:
Aw come on buddy, my Corolla beat your times on both Oran Park layouts. I just didn't include the times on here because I only wanted Soarer lap times, and because I know how easily embarrassed you get.
I like that idea. Wait until mine is finished then we'll organise a real tour.
Jeff Harper
V8 Track car
Wednesday, March 24, 2010 - 10:12 pm, by:  Jeff Harper (Jeffh) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wakefield Park 1:11:11
V8, non turbo, slicks, tein suspension, 5sp manual, 4 pots front 2 pots rear, adaptronic engine management and only 177kw rear wheel.
http://tarsoarer.blogspot.com/
Phil Gibson
Thursday, March 25, 2010 - 12:02 am, by:  Phil Gibson (Sciflyer) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ali Saeed wrote on Sunday, March 21, 2010 - 11:56 pm:
They do but they cant run evening events on the long track due to lack of lighting
I actually like the track though
My pb - 58.7 short track
stock V8 auto with suspension & brake work, LSD, weight ~1400kg
Andrew McKellar
Reg: 06-2008
Thursday, March 25, 2010 - 12:37 am, by:  Andrew McKellar (Toymax) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Jeff and Phil, just the stuff I'm looking for.
Jeff, thanks for the link to the blog too - an excellent read and some good photos there. I sent you a PM.
Ali Saeed
Thursday, March 25, 2010 - 01:35 am, by:  Ali Saeed (Ali) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
was that with supra club Phil? i havent really heard about anyone running the full track
Phil Gibson
Thursday, March 25, 2010 - 11:03 am, by:  Phil Gibson (Sciflyer) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
nope thats with these guys
http://www.nolimitevents.com/news.php
They run evening sessions every month, highly recommend :-)
Andrew McKellar
Reg: 06-2008
Friday, December 23, 2011 - 06:46 am, by:  Andrew McKellar (Toymax) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Finally time for me to post something here...
Wakefield Park 1:10.3
Ben Lipman
Friday, December 23, 2011 - 08:27 am, by:  Ben Lipman (Ben12a) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don't you mean 3 years, 1 minute, and 10.3 seconds
I forgot this thread was here.
Mallala 1:21.6 on semi slicks, stock motor and driveline. Lightened with backyard aero and off the shelf suspension mods (2.5deg camber front and 1.5 rear) Details in the track car thread.
Next session was quicker in both first and second sectors, but in the sand trap in the third...hoping new front end is more efficient, and the new engine management, highflows, and superspark adds a bit of oomph under the bonnet.
Friday, December 23, 2011 - 10:35 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That's a very good time for Mallala Ben.
Phil Gibson
'91 UZZ30, '91 manual UZZ31 track bunky, '94 blk/blk UZZ31
Tuesday, December 27, 2011 - 11:09 pm, by:  Phil Gibson (Sciflyer) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Barbagallo short - 57.57sec
Khalid Sarwari
vic
Reg: 04-2011
Friday, December 30, 2011 - 10:08 pm, by:  Khalid Sarwari (Harcourtsoar) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1.57 Philip island 2jz manual 5 speed 4 pot front brakes and single rear, no boot lining or rear seat with wolf stand alone ecu, making 275rwkws on a comfortable 16psi boost with Yokohama a048 semi slicks and tein suspension, sway bars and the rest done too.
Carl Mccormack
'91 Soarer TT
Reg: 09-2010
Sunday, January 01, 2012 - 10:02 pm, by:  Carl Mccormack (Eville) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Lakeside First time there
Dry 1.14
Wet 1.17
Andrew McKellar
Reg: 06-2008
Sunday, July 08, 2012 - 06:27 pm, by:  Andrew McKellar (Toymax) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I should have added this a few weeks ago.
Eastern Creek extended circuit:
2:19.9666
Bet nobody else has done a time on that yet!!
Clayton Carlyle
v8 soarer twin turbo
Reg: 04-2009
Monday, July 09, 2012 - 02:22 pm, by:  Clayton Carlyle (Clayton) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Andrew is the extended track same as WTAC 2011, 2012??
Andrew McKellar
Reg: 06-2008
Monday, July 09, 2012 - 09:43 pm, by:  Andrew McKellar (Toymax) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No mate, the time attack folk run on the GP circuit, which is 3.93km. The extended circuit is 4.54km.
Clayton Carlyle
Reg: 04-2009
Wednesday, July 11, 2012 - 09:50 am, by:  Clayton Carlyle (Clayton) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ah right, it would be good to see your car on display at this years WTAC???
Andrew McKellar
Reg: 06-2008
Tuesday, July 17, 2012 - 03:19 pm, by:  Andrew McKellar (Toymax) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
WTAC is on the same weekend as our Wakefield Park state round, so I'll be in Goulburn mate...
