Clayton Carlyle
TryHard NSW v8 soarer twin turbo
Posts: 334 Reg: 04-2009
| Congrats on getting this thing to the track! Wakefield next? |
Aaron Casey
Goo Roo NSW '94 2jz JZZ30 gttl, '93 UZZ31 track, VT, 2x Leyland Mini's
Posts: 3709 Reg: 08-2005
| Sure is! Booked for circuit club october 6th. Hopefully I can get some supra rear brakes and all the fittings for the surge tank so I dont have to run 60l or above of fuel like at marulan! |
Aaron Casey
Posts: 3722 Reg: 08-2005
| ok.... Wakefield park. 1:14.019 timed session 1:13.4 in untimed session Was 28-30 degrees today out there air temp. tyres really felt it. Man car needs something power wise, struggling down the straights with just a cat back haha |
Justin Hughes
Goo Roo Victoria V8 Soarer
Posts: 1515 Reg: 07-2005
| .... you need one of these ......
Spencer Cameron
TryHard NSW JZZ30
Posts: 330 Reg: 04-2008
| More power is the solution to almost every problem! And if it doesn't solve said problem, it at least makes problems more entertaining. |
Spencer Cameron
TryHard NSW JZZ30
Posts: 331 Reg: 04-2008
Justin Hughes wrote on Monday, October 06, 2014 - 07:50 pm:
http://youtu.be/U81_0waqEWA?list=PL12C0C916CECEA3BC Video of someone taking that seriously.. |
Justin Hughes
Posts: 1516 Reg: 07-2005
| HAhahahahaaaaaa - Awesome ROFL |
Aaron Casey
Posts: 3723 Reg: 08-2005
| hahaha yeah thats it... I was catching most cars through corners then when they would finally wave me past down the main straight... I'd struggle to get past haha and these are bmws, mx5s ft86s etc... |
Ben Lipman
Goo Roo SA Soarer TT manual, plus TT track car, plus a spare shell
Posts: 3849 Reg: 04-2006
| There was a bit of chat in my thread about Wakefield park lap times. I have collated those times I can find for past and present SoarerCentral members into a single table. There is a persistent rumour that Damien has done a 1:06 so I included it in the notes. And Aaron - I listed your unofficial time. There are some other Soarer times I found on NATSOFT, however I could not find them on the forums so I didn't include them. (Tozzi, Ruscoe etc)
Time | Driver | Engine | Tyre | Remarks | 1:07.5780 | Ben Lipman | 1JZ | Semi (R888) | | 1:07.7300 | Damien Smith | 1UZ twin turbo | Slick | Possibly done a 1:06 something. | 1:08.6625 | Andrew Mckellar | 1UZ | Slick | | 1:09.6140 | Shaun Chiew | 1JZ | Semi (RE55) | | 1:10.7100 | Cameron Spencer | 1JZ | Semi (KU36) | | 1:11.11 | Jeff Harper | 1UZ | Slick | | 1:13.4 | Aaron Casey | 1UZ | Semi (R888) | |
Spencer Cameron
TryHard NSW JZZ30
Posts: 332 Reg: 04-2008
| I feel kinda petty for pointing this out but the ku36 isnt a semi, its a high spec road tire for anyone too cheap (eg. Me) to spend the money on a better equivalent like the advan ad08, toyo r1r or Michelin pilot sport. Why do i go into the detail? Well, for anyone thinking of putting them on there soarer, don't. They're good on the street, pretty descent in the wet, but under a heavy car thats prone to a bit of wheel spin they're prone to delamination. I've had 2 pairs literally come apart at the seams under my soarer.. |
Andrew McKellar
DieHard NSW V8 Soarer Sports Sedan
Posts: 767 Reg: 06-2008
| And you could get Spencer's name correct too! I take it you have therefore committed to updating the table every time someone beats their PB or new cars/drivers come into the mix? Very nice. |
Ben Lipman
Posts: 3850 Reg: 04-2006
| When I copied it from Natsoft it was Cameron Spencer, LOL.I can update it, no problems. There would be less than 5 of us actually running cars at Wakefield, and maybe 10 who read this thread. Shouldn't be too labour intensive. Spencer - They market the Kumho as a semi slick, but I agree it is not. This is the reason I put the type of semi in the brackets as to compare a time set on a KU36 to a Hankook soft would be unfair.
Time | Driver | Engine | Tyre | Remarks | 1:07.5780 | Ben Lipman | 1JZ | Semi (R888) | | 1:07.7300 | Damien Smith | 1UZ twin turbo | Slick | Possibly done a 1:06 something. | 1:08.6625 | Andrew Mckellar | 1UZ | Slick | | 1:09.6140 | Shaun Chiew | 1JZ | Semi (RE55) | | 1:10.7100 | Spencer Cameron | 1JZ | KU36 | | 1:11.11 | Jeff Harper | 1UZ | Slick | | 1:13.4 | Aaron Casey | 1UZ | Semi (R888) | |
Aaron Casey
Posts: 3728 Reg: 08-2005
| Haha yeah hopefully its an easy table to keep up to date... being trying to find quickest na 1u on wakefield on semi slick and I cant seem to find much. Seem they get around 1:15ish then all go slick tyre. Just shelled oul large amount of budget for some advan a050, will have to mount to xd9s off the blue one (one hell expensive parts car!) so with front undertray sorted and some suspension and alot of driver tweaks Id love to get somewhere into the 1:11s or 12s. Cant wait to see what yours will be doing Andrew with new motor and gearbox setup! And Ben with the extra weight taken out, hopefully you guys will be cracking 05's |
Aaron Casey
Posts: 3732 Reg: 08-2005
| New pb of 1:12.2 (racechrono in untimed session) and 1:12.35 for timed on natsoft! Tyres really worked! Was no other mods as was fixing stuff more than modifying lol. One lap I had -1.3 showing half way through lap as really hooked up first half but then red flags came out for a person broken down... which was the thing for the day I spent half my sessions on red flags or in pits so only got a few proper laps in.. |
Ben Lipman
Posts: 3860 Reg: 04-2006
Time | Driver | Engine | Tyre | Remarks | 1:07.5780 | Ben Lipman | 1JZ | Semi (R888) | | 1:07.7300 | Damien Smith | 1UZ twin turbo | Slick | Possibly done a 1:06 something. | 1:08.6625 | Andrew Mckellar | 1UZ | Slick | | 1:09.6140 | Shaun Chiew | 1JZ | Semi (RE55) | | 1:10.7100 | Spencer Cameron | 1JZ | KU36 | | 1:11.11 | Jeff Harper | 1UZ | Slick | | 1:12.2 | Aaron Casey | 1UZ | Semi (R888) | | Nice work Aaron. I still believe your 'optimum lap' is currently around a 1:10 to 1:10.5. |
Aaron Casey
Posts: 3733 Reg: 08-2005
| Yeah ill have to review the sessions on phone ill be looking at soon. See if I can make something of it. 1st time I really used it properly, didnt have enough data on phone to add video so just used gopro. I think thats possibly the fastest na v8 on semi slicks?? Everyone else ive found are 1.14ish then go full slick? |
Aaron Casey
Posts: 3734 Reg: 08-2005
| Ok just went through all the sector times.. seems optimal lap is a 1:10.20! Wow I need some work on my driving haha. Figure out what to do with front brakes... then try go for it again!! |
Aaron Casey
Posts: 3741 Reg: 08-2005
| Marulan driver training centre, long track. 49.54 |
Aaron Casey
Posts: 3753 Reg: 08-2005
| New Wakefield pb of 1:10.12 on the yokohama AO50 |
Clayton Carlyle
Posts: 357 Reg: 04-2009
| Wow Aaron, your smokin for NA. |
Ben Lipman
Posts: 3893 Reg: 04-2006
Ben Lipman wrote on Monday, December 08, 2014 - 05:22 pm:Nice work Aaron. I still believe your 'optimum lap' is currently around a 1:10 to 1:10.5.
Told you. Wakefield Soarer leader board.
Time | Driver | Engine | Tyre | Remarks | 1:07.5780 | Ben Lipman | 1JZ | Semi (R888) | | 1:07.7300 | Damien Smith | 1UZ twin turbo | Slick | Possibly done a 1:06 something. | 1:08.6625 | Andrew Mckellar | 1UZ | Slick | | 1:09.6140 | Shaun Chiew | 1JZ | Semi (RE55) | | 1:10.12 | Aaron Casey | 1UZ | Semi (A050) | | 1:10.7100 | Spencer Cameron | 1JZ | KU36 | | 1:11.11 | Jeff Harper | 1UZ | Slick | |
Aaron Casey
Posts: 3758 Reg: 08-2005
| Ill have to spend some time figure out how to do the table on my phone as dont get on a laptop much, so you dont have to keep updating it for me haha... Shaun Chiew, I'm comin after you!! And yes Clayton I'm pretty stoked considering im roughly 130-140rwkw at the moment with speed limiter still. Ill try one more na see if I can crack a 1.09 then its time to get serious |
Ben Lipman
Posts: 3905 Reg: 04-2006
| I did a 1:09 on 150rwkw (essentially stock with a front mount) and all steel body. You have a better torque curve but slightly less power. You also have better weight distribution. I think you will get there NA. |
Andrew McKellar
Posts: 800 Reg: 06-2008
| I looked, but can't seem to find any EC/SMP GP circuit times to compare to? Anyway, 1:46.78 for SMP GP circuit after the recent improvements. |
Justin Hughes
Posts: 1532 Reg: 07-2005
| ... do you boys need tyres ? - I have a bagload of 18" Pirelli 265 Slicks. |
