  Soarer Central * Track and Major Rebuild Car Projects * Ford xr6T in an LTD soarer? Previous Previous    Next Next
John Stafford
Qld.
Soarer UZZ31 GT-L V8, 11 second XR6T
Reg: 02-2010
Monday, September 21, 2015 - 05:35 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all,
I have recently bought a BF xr6T. I has had an SCT chip on a rebreathed xr6t engine. I has a $6000 plus inlet manifold, bigger injectors and a big exhaust on the standard 35 turbo with big stage 2 intercooler and boxed air intake. It does 11 second quarters with around 400 klws at the wheels through a stage 2 rebuild 6 speed auto with a 2000 hp main shaft (gearbox fix was about $7000). It is a weapon to say the least.
I still love my Soarer more but this Ford is really nice. If you breath on it the back comes around to meet you if you are not careful.
I wonder one day when my V8 is at the end of its life, may be many years yet as it is faultless now, that I might try to put one of these amazing Ford turbo 6s in it and wondered if anyone else has ever done such a thing. I am sure the engine is higher but a modded bonnet is not too much of a challenge if other things work ok.
The gearbox is one of the things that make this engine a fantastic powerplant.
Am I the first to think of such a mod and if not what are the difficulties?
Cheers John
Scott Vim
Soarer (1uz) Chaser (1jz)
Reg: 12-2010
Monday, September 21, 2015 - 10:00 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What is the ford worth? Interesting setup and will out perform cars worth 10x the price.
John Stafford
Qld.
Reg: 02-2010
Tuesday, September 22, 2015 - 04:39 am, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I bought it for $10,500 plus had to roadworthy and register it, plus replace centre bearing on Tailshaft and half shaft, a tyre and a few other things but all up it cost me about $13,000. Pretty good for a Ferrari beater hey!
John Street
Uzz31 V8 , 2015 VW Jetta TDI, 2009 Saab 9-3 Turbo
Tuesday, September 22, 2015 - 01:03 pm, by:  John Street (Rex2ce) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
On FB there is a page about a Soarer with a twin turbo LS1 in it
John Stafford
Qld.
Reg: 02-2010
Thursday, September 24, 2015 - 08:02 am, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can you give me the link, I can't find it. Cheers
John Street
Thursday, September 24, 2015 - 05:05 pm, by:  John Street (Rex2ce) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
https://www.facebook.com/photo.php?fbid=874766662598265&set=gm.928550440517523&type=3&theater
John Stafford
Qld.
Reg: 02-2010
Thursday, September 24, 2015 - 05:21 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi John, that info is not available for some reason, maybe I am not in that loop?
John Street
Thursday, September 24, 2015 - 06:58 pm, by:  John Street (Rex2ce) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just clicked on the link,opens for me, PM me your email addy and I'll send link
John Stafford
Qld.
Reg: 02-2010
Friday, September 25, 2015 - 04:43 am, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
disciplingleaders@gmail.com
Thanks John
Phil Gibson
'91 manual supercharged UZZ31 track bunky
Wednesday, November 04, 2015 - 11:06 am, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The problem with the Falcon 6 is its huge - like massive, way longer and taller (and heavier) than the JZ. In height and length it will be touch and go whether it fits i reckon
John Stafford
Qld.
Reg: 02-2010
Wednesday, November 04, 2015 - 01:45 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes Phil, it is huge. I would have to make a big hole in the bonnet to get it in that is for sure, it looks like about 3 centemeters upwards and I am not sure if it would fit sideways, between the spring towers, with the big inlet manifold that I have from Process west but the ordinary manifold looks like it could fit. but the width with the turbo will be tight if I was to give it a go.
The 6 speed box is big too so may need a bigger trans tunnel too.
If anyone hears about this mod being done I would love to talk to the person to see what it involves.
I am not in a hurry to do this, just wanting to see if it is worth starting. It would require some serious electrical work too, no doubt.
If I am too optimistic, maybe someone is selling their supercharged Soarer V8 car or taking their ride back to standard and wants to sell the supercharger set up??
Scott Vim
Reg: 12-2010
Wednesday, November 04, 2015 - 07:38 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The money required to do that could get you a serious 1uz setup or spend less and have a 1jz pushing out 300rwkw. If I was going to do engine swaps I would do a 2jz-gte no
John Stafford
Qld.
Reg: 02-2010
Wednesday, November 04, 2015 - 11:57 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes, it is looking like that Scott. Thanks for those who gave an opinion.
Scott Vim
Reg: 12-2010
Thursday, November 05, 2015 - 10:26 am, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have done a big engine swap the costs stack up over time. Things don't work quite as well as they should and mechanics hate touching it. Can't remember what I spent but would have been at least $30k to have something that wasn't exactly ideal. In my instance it always leaked oil from the sump. Standard sump did not fit so needed to be custom. My opinion is you will spend big and still have lots of issues. When you finally get it right something will break.
John Stafford
Qld.
Reg: 02-2010
Thursday, November 05, 2015 - 10:33 am, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks Scott, just let me know when you are selling yours :-)
