Tuesday, September 19, 2006 - 09:18 pm, by: Tim Pike(Keydecoder)
I don't know if this is posted elsewhere (I couldn't find it when searching). But if anyone is interested in the fuse locations for the drivers kickpanel fuse box, I'm pretty sure this is what they are:
Interior fuse box... (cheers to Dave Hart for finding these, which are apparently somewhere in the Soarer Bible)
1 - Electric Mirrors 20A 2 - Air Suspension 20A 3 - Alternator 7.5A 4 - Audio/Multivision (EMV)/Auto Air Con/Multi Info Display/Lights. 7.5A 5 - Width/plate/tail/brake lights. 15A 6 - Auto Air Con. 10A 7 - ? 8 - Multi vision (EMV)/multi info display/con light/computer. 15A 9 - Wiper/oil film remover. 20A 10 - Cornering light/combination type computer.15A 11 - Meter/warning & indication lights. 10A 12 - Auto drive/EFI & ECT computers. 7.5A 13 - Brake light/shift lock/computer. 15A 14 - Air bag warning light/con light/computer. 15A 15 - Meter/chargewarning light/computer. 7.5A 16 - Lighter/meter/shift lock/clock. 15A 17 - Active suspension computer. 15A 18 - Radio no2/multi vision/audio/multi information display/remote mirrors. 7.5A 19 - 4WS computer. 10A
The locations in the panel are as in the diagram. The numbers in brackets correspond to the numbers above.
Edit: (1) and (2) in the bottom box should be (3) and (4).
Wednesday, September 20, 2006 - 12:15 pm, by: Mike Triggs(Mikeandimah)
On the '97 the foglights have another fuse in a separate holder/small fusebox (actually it's set up for 4 fuses but our model had only one position filled) behind the main under-dash one. A mongrel to get at and almost impossible to see without (as someone put it) turning into a dwarf and then standing on one's head.
