Have a motor ecu and wiring here from a jzz30 that will be going into another car. Now with the JZA70 ECU, it has a output wire to connect to the CEL.
The jzz30 seems to be different, Have been comparing the jza70 and jzz30 ecu pinouts, and see that the jzz30 ecu has no such wire from the ECU to connect to the CEL (for counting flashes).
Am wondering is there anyway I can be able to check error codes with a z30 1jz in another car?
On the jza70 ecu, the pin labelled "W" is the CEL wire, I cant find this pin on the jzz30 pinouts.
