  Soarer Central * Electrical * EMV blank screen Previous Previous    Next Next
Chris Lock
sa
Reg: 03-2008
Saturday, July 24, 2010 - 05:37 pm, by:  Chris Lock (Sledge) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Recently my EMV has been acting a little funny.
When i press one of the buttons on the right to get to the change channel, or change aircon settings, the screen just goes white with nothing showing at all, and nothing able to be pressed.
I switched the EMV over into another soarer and the same thing happens, so the issue must be in the EMV itself somewhere.
Any of the guru's here able to enlighten me as to what it could be and how to fix? or would it be too hard?
Chris
Chris Lock
sa
Reg: 03-2008
Monday, July 26, 2010 - 04:47 pm, by:  Chris Lock (Sledge) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I pulled the EMV out, and pulled it apart as far as i could. (there's some wires connected which i'm not sure if they unplug or not)
I can't see anythign loose/leaking etc.. in fact it looks nearly brand new...
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Monday, August 16, 2010 - 06:18 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
contact damian ware
Richard Luong
SC400 V8
Reg: 03-2010
Monday, August 16, 2010 - 09:37 pm, by:  Richard Luong (Reggiebangbang) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
May as well post this here, I've pulled mine apart (not a fun time), turns out at the moment looks like a blown lamp, now anyone happen to know the watts that lamp pumps out?
I'll be putting in a PCB with an array of LED this looks like by far the easiest and best long term solution, but this all depends if the owner of the EMV wants to go this direction.
Luke Gomer
Dorset
Uzz31 LTD
Tuesday, August 17, 2010 - 03:17 am, by:  Luke Gomer (Luke) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just repair the thing properly.
Failed EMV lighting tubes account for less than 5 % of backlighting issues .
Spare parts for EMV screens are readily available now .
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Tuesday, August 17, 2010 - 04:56 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
contact damian ware
Tom Richards
Wednesday, August 18, 2010 - 03:14 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
contact martin
http://www.plmsdevelopments.com/
Nathan Richardson
N.T.
UZZ32 #445 (V8 Supercherged 5Speed. 291RWKW)
Wednesday, August 18, 2010 - 09:25 pm, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maybe check the earth wire too.
It attaches to the car body through a screw on the right side that holds the centre console in under the dash.
