  Soarer Central * Electrical * ARGH! ECT error 42 with a twist.. Previous Previous    Next Next
Austen Menze
GT-TL
Reg: 07-2009
Thursday, September 09, 2010 - 06:30 pm, by:  Austen Menze (Mercyfulfate) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
After putting a GT-TL dash in (woot i have a fuel guage now!) it throws an ECT42 error with a flashing OD light.
After reading MANY posts, this error always sends the speedo dead. The thing is, my speedo is fine.
It drives normally, so what could this possibly be? Is there more than one speed sensor?
Ali Saeed
Friday, September 10, 2010 - 05:49 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
there are 2 speed sensors
Austen Menze
GT-TL
Reg: 07-2009
Friday, September 10, 2010 - 06:42 pm, by:  Austen Menze (Mercyfulfate) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ah thanks, any idea on which one I would need? I know that one if for the speedo, but no idea on what the other one is for.
Justin Camilleri
Had a 85 MZ10, 92 TT, Now 91 TT
Saturday, September 11, 2010 - 07:46 pm, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Austen, I have had the same problem for 4 years. It's time to start doing something about it. I have no idea which sensor is no:1 or no:2, so I purchased the 2 from Amayama for $138 posted. Will have them in in 2 weeks.
Austen Menze
GT-TL
Reg: 07-2009
Saturday, September 11, 2010 - 08:20 pm, by:  Austen Menze (Mercyfulfate) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
138 posted for both? That's an awesome price! I had contacted Amayama on Friday about these sensors actaully haha!
As with you, I have no idea which sensor is dead so I just asked for both. Let me know how it goes.
Was your speedo working fine Justin?
Justin Camilleri
Saturday, September 11, 2010 - 09:09 pm, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My speedo works fine. Every time I drive the car, just as it hits 1.1kms on the trip computer, the ect warning comes up then the flashing of the OD. Every time. Sometimes when I turn on the low beams it gets rid of the dash warning.
Austen Menze
GT-TL
Reg: 07-2009
Monday, September 27, 2010 - 09:09 am, by:  Austen Menze (Mercyfulfate) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Justin, my sensors are on the way finally.
Have you received yours yet? I'm keen to see if it fixed the problem.
Justin Camilleri
Monday, September 27, 2010 - 09:33 pm, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Put both of them in over the weekend, unfortunately did nothing. The error still appears. It's probably the wiring, which I will check later on. Hope you have better luck mate.
Ben Kelly
Lakemba
v8
Tuesday, September 28, 2010 - 04:46 pm, by:  Ben Kelly (Ace) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys perhaps we can form the error 42 club. I have had this problem for about three months and have had niall wanting to recon the transmission which sounds like overkill. Strange thing about why it would occur just at the same time you put a dash in Austen. Funny thing is that It happened to me after dash removal and reinstall as well. Im going to start with replace speed sensors, replace dash, recon transmission. Justin I take it you have two spare speed sensors now? would you like to sell them on the basis that I will pay your expense if they fix my problem?
Austen Menze
GT-TL
Reg: 07-2009
Wednesday, September 29, 2010 - 07:02 pm, by:  Austen Menze (Mercyfulfate) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just got my speed sensors today, but the motor is still in bits while I get a replacement head sorted so I can't test them out.
Ben, did you do a dash swap or did you simply remove and reinstall your dash?
I never got an error with my old dash but it wasn't one with a scrolling screen so hmm..
Strange problem though!
Austen Menze
GT-TL
Reg: 07-2009
Wednesday, September 29, 2010 - 07:08 pm, by:  Austen Menze (Mercyfulfate) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It could be an earthing problem? No idea how it's earthed though.
It may be worth throwing an earth wire on the transmission case to the negative terminal on the battery. Would only take a couple minutes if you have some spare wire laying around.
Ben Kelly
Lakemba
v8
Wednesday, September 29, 2010 - 07:16 pm, by:  Ben Kelly (Ace) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Austen i just had some guys take out and replace the dash cos they put a gps sensor on top. i doubt this is the problem but its curious it happened just afterwards. I have read another thread mentioning the same thing, then i read another saying that the dash 'cleans up' the signal from the speed sensor to the ecu...whatever that means. Justin has agreed to sell me his speed sensors so will let you know how goes. like you my speedo works fine and the ect error shows up at almost exactly 1.1kms. i recently noticed the doors dont lock either. not sure when this started. the tranny seems to shift fine so im still thinking it is the sensors. please let me know how you go.
Ben Kelly
Lakemba
v8
Wednesday, September 29, 2010 - 07:24 pm, by:  Ben Kelly (Ace) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
also youre right there are two sensors. apparently there is a different mechanism for both. error 42 relates to sensor 1 but apparently this could also indicate an error with sensor 2 (explaining why the speedo still works). An auto shop i visited who know lots about these transmissions suggested that it could be a shifting problem which might not be noticable cos of the automatic pressure changes to the solenoids (!?). Damian Ware suggested to me that its likely to be either one of the sensors or the torque converter locking up. I havent thought of earthing of the tranny. My earthing should be BETTER if anything cos the guys that did the stereo install (prior to the fault) put in an extra earth - but its an interesting idea. apparently also the sensors can be tested in situ with a voltmeter - ive heard 600ohms resistance quoted but not sure on which sensor.
Austen Menze
GT-TL
Reg: 07-2009
Wednesday, September 29, 2010 - 07:30 pm, by:  Austen Menze (Mercyfulfate) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
580-680ohms for both sensors in the japanese manual. Damn I wish I could read the rest of the thing though!
Austen Menze
GT-TL
Reg: 07-2009
Wednesday, September 29, 2010 - 07:42 pm, by:  Austen Menze (Mercyfulfate) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hmm, can you change the gear selector with the ignition off without having to press the ejector seat button (red shift lock button next to the shifter)? I can.
Ben Kelly
Lakemba
v8
Wednesday, September 29, 2010 - 07:48 pm, by:  Ben Kelly (Ace) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
haha i wish you could too buddy. Im sure glad youre on the case though :-)
im gunna go and see Paden (unique automotive in nsw) tomorrow and get his opinion.
Ben Kelly
Lakemba
v8
Wednesday, September 29, 2010 - 07:54 pm, by:  Ben Kelly (Ace) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Austen. no. no i cant. hold on wtf? noone can do that! just checked to make sure too...nup. could you before!? from memory that button just pushes down a rather large plastic lever- more of a physical thing than electric...maybe theres a coincidental problem around the selector housing also?
Austen Menze
GT-TL
Reg: 07-2009
Wednesday, September 29, 2010 - 08:03 pm, by:  Austen Menze (Mercyfulfate) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've always been able to shift without pushing the red button haha. Tell chicks it's the NOS button, I hit it and floor the gas at the same time lol. OH HEE HEE WOW U HAZ NAWS :-O
But hmm okay, yeah I've seen the big white plastic lever thingy, it does nothing on mine. I was hoping it was a sensor attached to that.
I've found some diagnostic diagrams in english, but I can't test them as I am unable to start my car for the next week or so :-(
Justin Cook
Friday, October 01, 2010 - 05:35 am, by:  Justin Cook (Justin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Austen your lock mechanism is just broken, should have nothing to do with your problem (Err 42). Some of them just die and you can then change out of P without pushing the red button.
Interesing issues, either,
* Sensors (speed 1 or 2, maybe check the 3rd convertor lockup sensor, its exactly the same as sensor 2).
* Wiring, make sure good connections either end.
* Dash might have an issue, try a spare one from a friend.
* ECU might have an issue try one from a friend.
J.
David Ward
3.0 TT & 2.5 TT
Reg: 10-2006
Saturday, October 02, 2010 - 04:27 pm, by:  David Ward (Djwtoyota) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi fellers,
hope you don't mind me hijacking your postings but while you're on the issue of sorting your speedo's I was wondering if anyone knows which output operates the speedo in the dash. I need to get a feed for an aftermarket speedo cum reversing warning system I'm fitting to my 1jzgte mounted Corona Mark 2. The old girl had a cable drive speedo and I don't use the actual Soarer dash. A signal from the computer would be best I guess as the dash loom is not used. Hope you can help me out,
thanks David
Austen Menze
GT-TL
Reg: 07-2009
Saturday, October 02, 2010 - 08:18 pm, by:  Austen Menze (Mercyfulfate) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Justin, will try all of the above when I stop getting effed around with my car.
Mobile mechanics who don't show up really piss me off..
Austen Menze
GT-TL
Reg: 07-2009
Sunday, November 14, 2010 - 06:50 pm, by:  Austen Menze (Mercyfulfate) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just an update, I put the old dash back in, and now the doors lock and I get no error code.
These things are really fussy!
Austen Menze
GT-TL
Reg: 07-2009
Monday, November 22, 2010 - 09:49 pm, by:  Austen Menze (Mercyfulfate) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Another update, I finally got the emanage ultimate installed, and it doesn't get a speed reading. Yet the dash displays the speed still.
