Monday, November 15, 2010 - 12:04 pm, by: Ben Leadbetter(Benj)
OK guys, I have pretty much worn out the search button on the site, and I apologise if I've missed a thread that explains this comprhensively, but I'm tearing my hair out here!
I purchased some HID's as my headlights are rubbish. I proceeded to follow one of the threads on here in regards to removing my headlights (aftermarket black ones). Easy.
Took them out, and it looks like the aftermarket headlights have a weird connector for the main light. Is it supposed to have a wiring harness that just plugs into the back? Mine has a rubber cap with wires running through, but they are just blade-ended and connect to the globe and the surround to power normal globes.
I took these out and tried to just retrofit them to the HID ballast and it just flickers. What do I need to get to connect them. Its a bit dodgy connecting the wires to the ballast so is there some sort of wiring harness I can put them into that will plug in?
Should I just buy a couple of HB4 heads like the above link, and splice the +ve and -ve wires from the car to the harness and then attach it all that way?
Tuesday, November 16, 2010 - 08:02 am, by: David Henderson(Hendo)
Are you talking about the 12v or high voltage side?
from the existing loom to the ballast a insulated spade is fine, I noticed with the kit I installed that the spade terminals weren't tight so I crushed them slightly with pliers to make them a tight fit.
Flickering may be due to a poor connection, check all the connectors are tight and the battery is charged when you switch the lights on
Evan Kaio DieHard Beautiful sunny good @ rugby 'Canes' country '91 UZZ31. 92 TT
Wednesday, November 17, 2010 - 04:06 pm, by: Gary Redman(Gary)
The after market low beams are different to the standard Soarer low beams, so if you got a HID kit to fit a Soarer, then you will have the wrong globes (been there, done that)
