Saturday, February 05, 2011 - 06:48 pm, by: Cameron Dearden(Crskmd)
*Posted this in mechanical but might be better suited here*
Hey all,
my soarer has been acting up lately.
mainly when you put •• foot down the car wont accelerate smoothly and the revs jump all over the place.
i have tried bridging the fuel pump ECU trick, didn't help at all.
Anyone else had this problem
I filmed what the 2 different things that happen now. EVEN IN NEUTRAL.
please watch the videos and let me know if any one has had similar problems. i would rather go to a mechanic and tell him the problem. instead of him having to find it first then fix it.
Sunday, February 13, 2011 - 04:40 pm, by: Cameron Dearden(Crskmd)
ended up taking it to sinergy for a diagnostic. came up with AFM error code, so they swapped it out for a new one just to test and the same problem was still there.
it seems to get better the more fuel there is in it.
my theory (probally wrong) is that when there is more fuel the weight of it helps push the fuel through the pump. and then when there is less fuel there is less pressure helping the pump and it struggles to provide enough fuel.
any way i can test if a new pump will fix it without having to buy one?
Sunday, February 13, 2011 - 04:55 pm, by: Matt Petersen(Mattmannz)
I doubt the weight of the fuel in the tank is making it run better but to diagnose the fuel system you need a pressure gauge on the fuel rail to show you the operating pressure.
Sunday, February 13, 2011 - 05:59 pm, by: Ben Lipman(Ben12a)
Broken or damaged fuel pick up? Some sort of blockage on the fuel pickup? Heaps of sediment in the tank? Crap fuel? Could be a lot of things.
No idea what the internal pump in the soarer looks like, but I can guarantee that the weight of fuel pushing on the intake versus the forces generated by the fuel pump will be negligable.
Saturday, February 19, 2011 - 09:15 pm, by: Cameron Dearden(Crskmd)
seems fixed!
ended up draining fuel tank to find a whole load of rust sediment and other junk in there. the fuel pump turned out to be rooted and only pumped 100 lph if lucky. and it had the stock fuel filter/prefilter.
also needed new pickup lines as the where completely clogged up with CR*P
