1
3
7
Days
Search
Topics
Tree View
Help
Soarer Central
Electrical
Serpentine belt is cutting into the electrical wire -
Previous
Next
Author
Message
Herman Sanchez
V8- Limited
Reg: 02-2011
Rating: N/A
Votes: 0 (
Vote!
Monday, February 14, 2011 - 10:17 am, by:
Herman Sanchez
(Herculees38)
Hi Guys,
As you can see the photo below, my serpentine belt is cutting into the electrical wire -
fdgdf
I have no idea what it is- tried to look for descriptions but couldnt find anything-
basically = My Question is what is that cable for & can i repair it easily.
Cheers,
Herman
Nathan Cryer
SC400 V8
Reg: 10-2009
Rating: N/A
Votes: 0 (
Vote!
Monday, February 14, 2011 - 03:03 pm, by:
Nathan Cryer
(Redrodeo)
Pretty sure its for the cam position sensor. The hole above your green arrow should have a clip in it to keep it in away from the belt.
Herman Sanchez
V8- Limited
Reg: 02-2011
Rating: N/A
Votes: 0 (
Vote!
Monday, February 14, 2011 - 03:20 pm, by:
Herman Sanchez
(Herculees38)
Hi Nathan,
Ok thnx now i know what it is -
as for the clip ill see what i can find -
but for the meantime i have used cable ties & they have worked quite nicely !
I want to repair the cable & use the right tools to patch up the wire, because one of the wires looks like it was cut right thru !!
Had a look in repco today and saw some of these
Should do the trick, maybe some sort of sheath over the top aswell..!
Adrian McGuire
soarer 2.5 turbo
Reg: 12-2010
Rating: N/A
Votes: 0 (
Vote!
Monday, February 14, 2011 - 03:28 pm, by:
Adrian McGuire
(Adro)
you should solder and heat shrink it for a good connection.
Herman Sanchez
V8- Limited
Reg: 02-2011
Rating: N/A
Votes: 0 (
Vote!
Monday, February 14, 2011 - 09:05 pm, by:
Herman Sanchez
(Herculees38)
sounds like a plan - solder & heatshrink -
ill have to check the fuse box aswell just in case
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Rating: N/A
Votes: 0 (
Vote!
Tuesday, February 15, 2011 - 01:06 am, by:
Boris Siljanoski
(Z2tt)
Try to re-route the wire or attach it to something using a cable tie.
-Color-
Black
Red
Green
Blue
Yellow
Purple
Orange
Cyan
Gray
White
-Font-
Arial
Courier
Symbol
Times
Verdana
-Size-
Smallest (-2)
Small (-1)
Normal
Large (+1)
Largest (+2)
Username:
Important Posting Information:
Administration
Log Out
Previous
Next
