Thursday, March 31, 2011 - 10:28 am, by: Christian Molenda(Christof)
Measure the ohm's of the original speaker with a multimeter, then measure the new sub. If they are both the same (4 ohms) then should be ok. If the standard is 8 ohms then dont do it or you will see smoke.
Friday, April 01, 2011 - 08:47 am, by: David Boyle(Amokzar)
Dave, From what i can tell the original AMP runs 2 ohm speakers and sub woofer (i have been researching into this too) where as most subs i can find are 4ohm. Hope this helps
