Saturday, April 30, 2011 - 12:38 pm, by: Ali Yazici(Wa_ali)
Guys,
Have a slight problem. As per the title, my drivers side window has stopped working.
Key facts: - Passenger window is operational from main switch - Passenger window is operational from passenger switch - All lights and other controls work - Checked all fuses (including the 15A IGN, 30A PWR and 30A Door fuses) and all good - Replaced the relay on top of kick panel fuse box with one in engine bay (exactly the same) and still no change - Checked the wiring in the door boot (between hinges) for broken wires (including and especially the white/black cable) and all is well - Got another switch (told to be in working order) plugged in and exactly the same symptoms as the previous switch!!!
I have the same issue with my Limited, been like this for months but is really irritating me now. Haven't found the problem yet, but I strongly think it's the window motor as well (the door switch has power, which seems at all pins... the window switch lights are on as well).
If I find anything I'll let you know, looking to pull apart the door either this weekend or next.
