  Soarer Central * Electrical * Jzz31 ecu on ebay.thoughts on if it could be ok.....???? Previous Previous    Next Next
Mark Bryant
tasmania
2jz na/t and rs4 stagea
Reg: 08-2010
Sunday, May 08, 2011 - 11:28 am, by:  Mark Bryant (2jz_nat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Found this on ebay
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=390311443083&ssPageName=STRK:MEWAX:VRI
Just wanted peoples thoughts to see if this would be worth the hassle of buying it.
Or has anyone heard of this group "ADVANCE"?
Monday, May 09, 2011 - 06:46 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Seems like quite a bit of money for something that is not going to provide a huge performance improvement. The video is good, but the advert itself makes no sense "Eliminate boost limiter" - uh, WHAT boost limiter? What boost for that matter? The video clearly states the EEPROM is configured for N/A!
