  Soarer Central * Electrical * Coil Pack Connector Part Number Previous Previous    Next Next
Ashley Leach
Tuesday, June 07, 2011 - 09:33 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
90980-11246
Just need to know if this is the correct part number for the coil pack connectors for a V8?
Anyone help?
Matchy Loi
GTT
Wednesday, June 08, 2011 - 12:14 am, by:  Matchy Loi (Ftk148) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I don't know much about the 1uz, but I always thought that the V8s have leads and not coil packs. Someone should come along soon and confirm.
Quick google of that number shows that it is a coil pack connector, suitable for the 1jz amongst other engines.
Ashley Leach
Wednesday, June 08, 2011 - 06:40 am, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok, well you don't know then
For the record
V8 have 2 coils. Each feeds on bank of 4 cylinders. 2 on each side
Dave Rose
wa
uzz31 v8
Wednesday, June 08, 2011 - 07:55 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i have some clips here ,but someone your way would have them on an old set of leads i would think?
Ashley Leach
Wednesday, June 08, 2011 - 07:59 am, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I bet they don't have a part number on them either...
I think that's the right part number. I'll get some sent and see!
Edit: nevermind, that PS pump kit is for a TT right?
Dave Rose
wa
uzz31 v8
Wednesday, June 08, 2011 - 08:24 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No its for a v8
Ashley Leach
Intermittently running - UZZ31
Wednesday, June 08, 2011 - 08:27 am, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So the part number : 04446-24012
has been S/S or is it wrong?
Brett Harrison
Wednesday, June 08, 2011 - 08:58 am, by:  Brett Harrison (Bretto) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
90980-11246
Same as TT,
Ashley Leach
Wednesday, June 08, 2011 - 09:02 am, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks so much Brett.
Just ordered a couple. I thought they might be the same!
Brett Harrison
Wednesday, June 08, 2011 - 02:34 pm, by:  Brett Harrison (Bretto) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just take your time assembling the new ones, make sure to get wiring in correct pin etc.
