  Soarer Central * Electrical * Interior lights not working Previous Previous    Next Next
Josh Hyland
Reg: 08-2011
Saturday, September 03, 2011 - 12:17 pm, by:  Josh Hyland (Hylander) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok so i was replacing the lights in the door, the ones that come on when you open the door. While i was doing that i noticed that it wasn't working and that none of the interior lights now work. Both sides of the doors and the centre light on the roof. It may be a blown fuse, i don't know, but which fuse would it be?
cheers
josh
Josh Hyland
Reg: 08-2011
Saturday, September 03, 2011 - 01:03 pm, by:  Josh Hyland (Hylander) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
and now when i turn the car alarm on, a few seconds later the alarm goes off
Joshua Rao
TT (for sale $5.2k), 97 Blk UZZ31, 97 JZZ30 vvti turbo white manual, 96 vvti turbo manual, Legnum VR4, MR2 sw20, Alfa 156
Reg: 09-2006
Saturday, September 03, 2011 - 02:34 pm, by:  Joshua Rao (Soaren1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Theres fuses in drivers side footwell next under carpet or in the engine bay
Josh Hyland
Reg: 08-2011
Saturday, September 03, 2011 - 02:45 pm, by:  Josh Hyland (Hylander) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yea just checked all the fuses earlier. all seems to be good
Matt Petersen
NA
Reg: 01-2008
Saturday, September 03, 2011 - 03:16 pm, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
