  Soarer Central * Electrical * Stereo problem Previous Previous    Next Next
Matthew Weaver
Reg: 01-2010
Friday, September 09, 2011 - 10:42 am, by:  Matthew Weaver (Spinna) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys as part from what you all know from my post is that im doing a interior make over. So my problem is this i've been at it for 3 days trying to find out why my stereo isn't working. And this is what i've checked
*all fuses are fine
*checked with a mulitmeter power is good
*And all the plugs are connected
So i've got my a/c working fine just not my LCD dvd player. It has me lost that there is power running into it its just not turning on any help would be great guys :-)
Tom Richards
Friday, September 09, 2011 - 11:39 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
you have +12v to the unit, but do you have ground/earth?
also, do you only need a single +12v, or are 2 required?
Matthew Weaver
Reg: 01-2010
Friday, September 09, 2011 - 11:50 am, by:  Matthew Weaver (Spinna) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
its all good mate thanks for responding i found the problem don't laugh LOL!!! I forgot to plug in the aerial didn't know that was ground now its working like a charm
Matthew Weaver
Reg: 01-2010
Friday, September 09, 2011 - 12:01 pm, by:  Matthew Weaver (Spinna) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
its funny how when you think everything is plug'd in there is always one tiny thing that you miss that you cant see until you look again
Tom Richards
Friday, September 09, 2011 - 01:01 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
if there is an earth pin on the plug, i would earth that and not just rely on the antenna providing the earth.
good to see a "simple fix."
