  Soarer Central * Electrical * OBD scan tool Previous Previous    Next Next
Brett Harrison
Monday, September 19, 2011 - 10:11 pm, by:  Brett Harrison (Bretto) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm after something that will read a OBD port, rectangular port in engine bay. As I have no other way of reading for fault codes, as the 1UZFE has been transplanted.
Ive noticed several scan tools available, but have no idea which one will read a 94 Celsior engine.
Anyone have any clues on this.
Brett Harrison
Tuesday, September 20, 2011 - 03:50 pm, by:  Brett Harrison (Bretto) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Surely someone must know what tool will plug into the engine bay OBD 1 port.
Is there a way to do it manually, with a test light ? As the engine isn't linked to the dash in a std car.
Scott Casey
soarer v8
Reg: 02-2008
Thursday, September 22, 2011 - 06:29 am, by:  Scott Casey (V8soarer_1991) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
try
http://www.obd1.com/
most obd1 is in the engine bay.
1uz top of engine
Brett Harrison
Saturday, October 01, 2011 - 11:36 am, by:  Brett Harrison (Bretto) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ive tried one scan tool but couldn't get a reading from the engine port. Ive emailed your link Scott so will see if they have any ideas.
Nathan Cryer
Rodeo V8
Reg: 10-2009
Tuesday, October 04, 2011 - 08:56 am, by:  Nathan Cryer (Redrodeo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Have you used the standard ECU with your transplant?
If you have connect a light to the "check" wire from the ECU and follow the paper clip diagnostics. The light will flash any fault codes.
The diagnostics port is unique to Toyota, it is not OBD1. I have tried a SnapOn scan tool but it only wants to talk to the inside round port.
Brett Harrison
Tuesday, October 04, 2011 - 12:27 pm, by:  Brett Harrison (Bretto) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Its running std ecu.
The diagnostic port has an output 'W' which is CEL output. In diagnostics mode it does give out a reading via the multimeter. However the voltage is in mV, and hard to read with out a test light. So I might need to get a low voltage LED to read it.
Nathan Cryer
Rodeo V8
Reg: 10-2009
Tuesday, October 04, 2011 - 06:34 pm, by:  Nathan Cryer (Redrodeo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
On the Soarer ECU it grounds the check light. Power for the light comes from the gauge fuse then through the light and then to the ECU to be grounded.
Check the wiring diagram and the end of the diagnostics page.
http://soarercentral.com/sc-forum/messages/1113/862.html?1100787369
Brett Harrison
Tuesday, October 04, 2011 - 07:54 pm, by:  Brett Harrison (Bretto) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for that Nathan,
Now that check light, is connected to 'W' in the diagnostics port, if I run a check light straight off that to ground, that should flash as per dash right ? Its definitely cycling a code when in diagnostics mode through 'W' port, but voltage is very low, not enough to run a light that I'm aware of.
Is this correct, or have I overly simplified this ?
Brett
Nathan Cryer
Rodeo V8
Reg: 10-2009
Wednesday, October 05, 2011 - 09:17 am, by:  Nathan Cryer (Redrodeo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine runs from positive to the light then to the W wire.
Brett Harrison
Wednesday, October 05, 2011 - 06:44 pm, by:  Brett Harrison (Bretto) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nathan, your spot on,
So for reference sake, bridge TE1-E1.
Then run a test light between B+ and W.
Fault codes will start flashing with ignition on.
Chris Lock
sa
Reg: 03-2008
Friday, February 28, 2014 - 06:23 pm, by:  Chris Lock (Sledge) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone seen this?
http://www.ebay.com.au/itm/2013-Vgate-v1-5-Mini-ELM327-OBD2-OBDII-Bluetooth-CAN-Scanner-for-TORQUE-A NDROID-/121228007516?pt=AU_Car_Parts_Accessories&hash=item1c39c0985c&_uhb=1
Reckon it would work?
Tom Richards
Friday, February 28, 2014 - 08:33 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
got one, works great with the apps on phones. EG torgue lite(free) torgue pro a couple of $'s
not for soarers , but most cars after mid 90's.
eg resetting codes in late model commodores.
Chris Lock
sa
Reg: 03-2008
Friday, February 28, 2014 - 08:58 pm, by:  Chris Lock (Sledge) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So doesn't work on Soarers then?
Tom Richards
Friday, February 28, 2014 - 11:02 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the scanners are OBD2 the soarers are not
Steve Gorman
Saturday, March 01, 2014 - 12:31 pm, by:  Steve Gorman (Steve_gorman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think 1997 and on JZZ31 soarers use OBD2 - at least mine does
Tom Richards
Saturday, March 01, 2014 - 02:23 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
steve is probally correct as i said above , OBD2 started in the mid 90's and i would think toyota would be leading the way.
Ian Rigby
'97 AE102, '95 JZZ30
Reg: 11-2010
Sunday, March 02, 2014 - 05:36 pm, by:  Ian Rigby (Hiro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tom Richards wrote on Saturday, March 01, 2014 - 02:23 pm:
OBDII was introduced in the US in about 1996 or so, Toyota actually took quite a while (say mid 2000s) to properly adopt it in Aus at least (not sure about Japan) - for that 10 year period they had their own proprietary setup that looks "like" OBDII but wasn't.
Steve Gorman
Sunday, March 02, 2014 - 05:43 pm, by:  Steve Gorman (Steve_gorman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
We have 2 1997 JZZ31 soarers in our household fleet and both have had aftermarket OBD2 scanners successfully used on them.
Goetz von Gneisenau
Reg: 03-2019
Monday, June 03, 2019 - 11:20 pm, by:  Goetz von Gneisenau (Sunshine) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If anyone is interested to know I have purchased an Actron CP9690 OBD scanner and it works great on my 1991 UZZ31.
Plugs into the round circular plug under the dash, does not work using the rectangular plug into the port on top of the engine (eventhough it comes with the rectangular plug).
Reads error codes and as well reads live data and all the other features..
Roland Elliott
uzz32 1uz-fe
Reg: 08-2014
Monday, June 03, 2019 - 11:49 pm, by:  Roland Elliott (Aussie2013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Goetz von Gneisenau wrote on Monday, June 03, 2019 - 11:20 pm:
I HAVE sent you an email
Scott Vim
Soarer (1uz) Chaser (1jz)
Reg: 12-2010
Tuesday, June 04, 2019 - 12:03 am, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sounds really good. What kind of money are we talking here?
Goetz von Gneisenau
Reg: 03-2019
Tuesday, June 04, 2019 - 12:16 am, by:  Goetz von Gneisenau (Sunshine) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I paid around $385 on Ebay, the sellers are mainly in the USA.
