Monday, October 03, 2011 - 11:03 am, by: Chris Priestley(Bimbo)
gday everyone.
im just getting the car ready for rego, and i noticed the light on my normal spoiler does not work. we opened inside the boot, and found a wire that goes to it, but it was disconnected.
will it pass rego without this light? the light is about 25cm long and 1cm thick.
Monday, October 03, 2011 - 09:29 pm, by: Jack Hawkins(Jack92)
Hey Chris, I had the same problem with my 97 spoiler light, Mine had 2 wires going into a plug and into the light and it turned out The polarity was wrong Im not sure if pre 97 is the same but if you have two wires coming out of the light try hooking them up to a battery both ways. Anyway hope that helps somehow Cheers Jack
Tuesday, October 04, 2011 - 09:09 am, by: Chris Priestley(Bimbo)
thanks tom i will try find one.
i dont think you can get in there to check everything because mine is 1 peice. nothing is glued or bolted together, its just peice of plastic with the leds inside it. unless i finely hack saw the top right off, then lightly glue it back on..
Tuesday, October 04, 2011 - 09:43 am, by: Tom Richards(Tomr)
hi chris, on the standard boot spoiler i have, if you remove it from the boot you will have full access to the light assy. its held on with a couple of screws.
if you are unable to repair it something like this could be used
Tuesday, October 04, 2011 - 12:21 pm, by: Chris Priestley(Bimbo)
thanks josh i will let you know.
we ended up getting the spoiler and light out yesterday. and then today we checked the power for the wires going to it, and they dont work. so we think its just a fuse, and we are just going thru the manuals now to find fuses etc. and hopefully thats it, otherwise i will hit you up for that light josh. i am not sure what kind of spoiler it is. but just looking at the light now its about 35cm long, and 1cm thick.
