Wednesday, October 05, 2011 - 12:02 pm, by: Chris Priestley(Bimbo)
the battery went flat yesterday so we recharged it. everything worked fine.
so i start it today, there is no dash, but everything else works in the car. i let it run for 15mins. then i turn the key off, the engine continued to run, i "turned the car on again with the key" then the car shut down, yet the stereo still played, i turned it off again, stereo still played, all the lights in the car stayed on.
i did the same thing again just to make sure nothing glitched...everything still did the same thing. i locked the car, and the lights are still on in the car. i can go turn the stereo on right now without the car even being on.
Wednesday, October 05, 2011 - 02:28 pm, by: Tom Richards(Tomr)
did you disconnect the battery before hooking it up to the charger? It is possible if you didnt that a voltage spike has done some damage to one of the ECU's.
