Tuesday, October 25, 2011 - 12:21 pm, by: Tom Richards(Tomr)
your power steering pump has leaked oil onto the alternator.
You need to put a "kit" into the pump, and clean all the oil off the alternator. the oil attacks the insulation on the windings and stuffs the alternator.
Tuesday, October 25, 2011 - 12:58 pm, by: Tom Richards(Tomr)
hi chris
thats an easy fix. check the PS fluid level and also for leaks onto the alternator every now and again. A leaking PS pump will stuff the alternator(and give the identical symptoms you had)
