  Soarer Central * Electrical * Please help - blown fuse, falls apart! Previous Previous    Next Next
Darren Bauer
Reg: 04-2010
Sunday, February 19, 2012 - 09:05 pm, by:  Darren Bauer (Dazmon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can someone help, I managed to short out the alternator and blew the 120A fuse, seemed straightforward enough, but trying to remove the thing its brittle and keeps falling apart. Are they just removeable like I assumed?
Dave Rose
wa
uzz31 v8
Sunday, February 19, 2012 - 09:50 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes Darren pull it out, wish i had said disconnect battery first
bet that made ya jump.
Darren Bauer
Reg: 04-2010
Sunday, February 19, 2012 - 10:27 pm, by:  Darren Bauer (Dazmon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can't pull it out, not much left to grab on to!
Will be easy to buy in the morning but difficult to actually replace!
Only got the 2 easy bushes in too!!!!!!
Removed a few things but not the alternator and should have, but could not get that bush in, tried for hours.
Matchy Loi
GTT
Sunday, February 19, 2012 - 10:33 pm, by:  Matchy Loi (Ftk148) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think there's a bolt underneath holding it in.
Aaron Casey
Sunday, February 19, 2012 - 11:45 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Main fuses have small bolts holding them in. Pull the fusebox apart to remove the two 10mm headed screws from underneath and will come out fine.
Darren Bauer
Reg: 04-2010
Monday, February 20, 2012 - 04:29 pm, by:  Darren Bauer (Dazmon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've rung up 5 wreckers, 1 Toyota and 1 Auto Elec, no-one can get this fuse. Never thought it would be so hard to get a fuse, and its such an essential one.
Matchy Loi
GTT
Monday, February 20, 2012 - 07:41 pm, by:  Matchy Loi (Ftk148) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I physically went down to toyots r us, $10.
Darren Bauer
Reg: 04-2010
Tuesday, February 21, 2012 - 11:13 am, by:  Darren Bauer (Dazmon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I did the same Matchy, Centre Rd Wreckers $2!
For those that are interested Centre Rd Wreckers (Springvale) has 3 Soarers. The fuse box I opened looked like it had never been opened, the fuses were mint.
Darren Bauer
Reg: 04-2010
Saturday, February 25, 2012 - 08:55 pm, by:  Darren Bauer (Dazmon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Dave,
can you help me with 1 more thing?
My wife drove it after I got it all going again, she drove it like a grandma coz she didn't trust my skills(!), when I went to drive it the shifts are different and it feels a bit different to how I remember it, have ECUs been reset or something like that?
Matchy Loi
GTT
Saturday, February 25, 2012 - 09:36 pm, by:  Matchy Loi (Ftk148) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That's exactly right, search for resetting the ECU. You should do it again.
Dave Rose
wa
uzz31 v8
Sunday, February 26, 2012 - 11:35 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Darren , it takes while to sort it self out, how did you go doing the top rack bush!!
