  Soarer Central * Electrical * Airbag Light Previous Previous    Next Next
Ashley Leach
Wednesday, June 06, 2012 - 06:31 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well fck.
just jumped in the car and my airbag light is now permanently lit when driving. Haven't touched the dash. Does anyone know what could cause this?
I Will attempt the "reset" on the weekend.
Ashley Leach
Wednesday, June 06, 2012 - 06:50 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
As a side note I'm getting a new battery on the weekend and cleaning the earth points. I'm getting this strange A/C panel dimming when the indicators are switched on.
So possible earthing/voltage problem might be causing this?
Victoria (The Nazi State)
Pretty Red Thing and The Black Rattler
Wednesday, June 06, 2012 - 08:01 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Right at the bottom.
http://planetsoarer.com/dashrepair/dashrepair.htm
The console earths possibly, or a crappy battery.
Ashley Leach
Wednesday, June 06, 2012 - 08:16 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm leaning towards battery. In any case the dash has to come out as it has a later model in it already. I have 3 other to pick from as well... :-/
Cheers Dan
I'll post up how I go.
Richard Crockett
UZZ30, 3xUZZ31 JZZ30
Wednesday, June 06, 2012 - 08:30 pm, by:  Richard Crockett (Crock) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The reset is fun Ashley. If you have to do it, make up 3 wires with female spade bit ends on each wire to plug into the OBD under the driver's dash. Read the tute well and have a go. Easy after an attempt or two.
Edison Koh
JZZ30 VVTi
Reg: 08-2010
Wednesday, June 06, 2012 - 10:04 pm, by:  Edison Koh (Reiven) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Check your driver's footwell fuses too.
I had the airbag warning in my 31. Turned out to be a blown instrument-gauge fuse.
As for the blinking A/C control light, mine was solved with new bulbs. T3 neo wedge i believe.
Alternatively, it might be your batteries.
Ashley Leach
Wednesday, June 06, 2012 - 10:19 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Edison - What else are the symptoms of the blown instrument gauge fuse? I would have thought it wouldn't light up at all...
Richard - sounds like it could get me quite angry...
Edison Koh
JZZ30 VVTi
Reg: 08-2010
Thursday, June 07, 2012 - 01:23 am, by:  Edison Koh (Reiven) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Forgive me for getting your hopes up Ashley.
Forum stomping and studying do not go well together.
My error was the ABS warning.
