Thursday, August 09, 2012 - 08:11 am, by: Blake Gloyn(Blakenz)
the ECU has two speed inputs from memory. perhaps one for the trans to work out shift points etc, the other most likely for the dash. I'm thinking your trans won't change gear if you disconnect one. THere is only one speed sensor unit on the trans though. at the rear, on the left from memory. a proper speed cut defender is best.
