Wednesday, August 22, 2012 - 04:54 pm, by: Anthony Dutton(Dutto77)
once installed the trans seem to be shifting way to early econ and power mode seem to be the same shifting at around 4600 wot.. also i been studying my logs and from what i can tell is that the closed loop is activated when the w/temp reaches 83 does this sound correct ?
Thursday, August 23, 2012 - 05:13 pm, by: Blake Gloyn(Blakenz)
unplug the 02 sensor and then take it for a drive. It's a grey plug between the front turbo and the alternator. The 02 sensor is located where the two turbos' exhaust gases meet, and just follow the wire forward about 30cm, and you will find the aforementioned plug. try it and see.
