Saturday, December 01, 2012 - 08:15 pm, by: Ian Johnston(Ted)
Not sure if it is correct, or if someone has wired up my lower turning lights to run only on low beam. They dont work as the early ones(with blinkers) Mine is a 1995 UZZ31.
Saturday, December 01, 2012 - 09:37 pm, by: Jesse Webber(Jessewebber)
94 onwards turning lights were replaced with dedicated proper 55w fog lights, controlled via a separate switch on the indicator stalk. They will only work when your parkers or headlights are turned on.
You'll notice the actual fog light housing and front bumper itself is different too a 91-93 model.
91-93 Turning lights 94-99 Independent Fog lights
Ian Johnston Goo Roo South Australia 1995 UZZ31, BA XR6Turbo Ute. 2007 VE GTS.
Saturday, December 01, 2012 - 09:42 pm, by: Ian Johnston(Ted)
I wondered that. Cant find a switch on the blinker stalk though. Also, I dont think it has the correct front bar and lights. Looks like it may have an earlier bar. Will have abetter look 2moro.
Sunday, December 02, 2012 - 04:42 pm, by: Ian Johnston(Ted)
Alls good. Found the switch on the blinker stalk(helps when you look at the correct stalk) Had been driving my Chev with blinker stalk on LHS Lights are different to my 91 model. Thanks for the help.
Friday, December 07, 2012 - 09:48 am, by: Bernie Simm(Mayhem78)
Alot do get altered. My 91 has a switch on the lower dash to seperately turn the lower bar lights on or off, provided the parks or headlights are on. I personally like the look of upper and lower lights on a soarer.
