Wednesday, January 30, 2013 - 10:02 pm, by: Jessica O'Brien(The_captain)
I have a 1991 V8 and it has a factory touch screen in the center console. It use to play up on really cold days but would show the screen when it was warm but now when i start the car the screen turns on but then goes to black. I can still use it cause i remember where almost everything is. It still works when i touch it but its annoying that i cant see anything.
pages 8 and 9 will fix most problems. It is an easy fix for any competent tech. You can remove the emv and give it with the printout to anyone trained in PCB repair
Thursday, January 31, 2013 - 11:58 am, by: Tom Richards(Tomr)
hi jess,
not sure if that is an EMV backlight problem.
I would do the fixes on page 8 and 9 and see what happens. You carefully remove the 3 SMD caps with a small iron. It is easier to remove the leaded electros by cutting them off.
Wednesday, February 20, 2013 - 02:45 pm, by: Tom Richards(Tomr)
peter, i would do that fix if you have not had it done. there is a fault that occurs in the actual emv computer that causes the screen to lose the temp and radio display when in the "normal" switch on mode.
