Evan Kaio wrote on Wednesday, February 20, 2013 - 04:53 pm:It is the permanent power to the radio tuner/DSP unit that is the problem.
I had the same problem for years. I ended up cutting the blue/yellow permanent feed to the tuner and used the switched ignition wire as power to the tuner. Tuner has permanent and switched power.
