  Soarer Central * Electrical * Ultrasonic Mirror Issue Previous Previous    Next Next
Adrian Sellick
Reg: 12-2012
Friday, March 15, 2013 - 11:39 pm, by:  Adrian Sellick (Haloeight) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Geday,
I used to have both ultrasonic mirrors working, now one of them doesn't squeal or heat.
Has anyone else had these stop working for no reason? If so, how did you fix it?
Tuesday, March 19, 2013 - 01:59 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Usually the drivers side doesn't work as it gets mangled as part of compliance to fit a flat mirror.
If yours worked, you are either lucky or illegal - or both but check the wires that go through the door hinges.
Adrian Sellick
Reg: 12-2012
Wednesday, March 20, 2013 - 02:18 pm, by:  Adrian Sellick (Haloeight) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cool, many thanks for the tips! I'll check it out.
