  Soarer Central * Electrical * ECU - 1991 UZZ31 - Help Previous Previous    Next Next
Greg Wyllie
Reg: 11-2010
Tuesday, May 14, 2013 - 05:16 pm, by:  Greg Wyllie (Bearshead) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all, my V8 Limited has been running rough and has been diagnosed with faults with main ECU.
Any suggestions where to have it rebuilt and approx. cost or where I could source one in better condition than my original. It is my daily driver so it needs to be close to Sydney, thanks Greg
Allan Langford
Reg: 05-2010
Tuesday, May 14, 2013 - 10:40 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wolf do a plug in replacement... $$$, questionable legality, but more power and better fuel economy
Jeff Bunsell
UZZ32 # 605
Reg: 03-2008
Friday, May 17, 2013 - 01:51 pm, by:  Jeff Bunsell (Jeffb) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Greg,
If it's a leaky capacitor issue and you're feeling brave the following link shows you the ones that will most likely need replacing.
http://www.toymods.org.au/forums/tech-conversions/68911-1uz-soarer-ecu-capacitor-replacement-info.ht ml
If your not then you might try the following:
http://soarercentral.com/sc-forum/messages/282/362578.html?1340793717
The Wolf v500 replacement one is ~$2k but if you're looking at upgrading the motor at some point in the future it's probably a good investment.
I'm running through the same sort of options at the moment myself so best of luck.
Greg Wyllie
Reg: 11-2010
Friday, May 17, 2013 - 03:42 pm, by:  Greg Wyllie (Bearshead) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jeff, I'm just trying to decide whether to have mine redone or chance buying a used one that has been done.
Getting mine redone means no daily driver which creates problems however as it is only the capacitors diagnosed as needing replacing I'm not buying any one else's problems either by using my existing ECU
