Saturday, July 06, 2013 - 08:34 am, by: Joseph Kelly(Phenonix)
Is there another route i could take to wire into the starter solenoid? I understand it is a very inaccessible area and was hoping there was wiring somewhere else i could tap into.
I have wiring to go to the starter wire in the ignition so i'm not sure if i can also go there with the wiring i need to do mentioned above Thanks
Sunday, July 07, 2013 - 06:52 am, by: Joseph Kelly(Phenonix)
Trying to install an auto start Boris, 2 modules, one going to the starter wire on the ignition, and the other says to go to the solenoid. Would the starter relay be a better point, where is that?
Yes you Can attach a wire to it. Pin should be Positive Trigger, You can remove the relay and normally the relay is labelled, then use a multimeter on the pins to rule out which wire you need to tap into.
