Thursday, August 15, 2013 - 06:32 am, by: Greg Albrighton(Greg130)
Hi Guys,
Recently purchased a 1991 4.0 V8, great car.
The EMV works great apart from GPS (no map disk) and the Trip Information/fuel consumption pages.
The fuel consumption page flat lines at 6 and the trip information page reads all zero,s.
It did have a Field TV box thingy fitted, have removed. Reconnected the cut pink wire, black/yellow and black/grey wires. On the large grey wire plug there were also two wires cut and joined into the Field box. If I connect the black wire nothing happens. If I connect the white wire the EMV shuts down after approx 1 min.
Now stumped as to what is wrong, seems like something simple is stopping it from working, any ideas as to the solution?
Thanks in advance.
Friday, August 16, 2013 - 06:38 pm, by: Greg Albrighton(Greg130)
Yes, seem to have fixed it.
Top tip, never assume someone else's wiring is correct, checked all the previous owners wire joins, a previous solder had dried out and wasn't making the correct contact.
Took her for a spin, worked just fine, well until I got back home and pressed the memory seat button which caused the EMV to shut down........blast more investigating to do.
