Tuesday, October 15, 2013 - 05:11 pm, by: Al Shield(Almigo)
Hi,
If anyone has installed this Jaycar Central locking kit in their Soarer successfully could you let me know which wires from the 386m unit you used and on which soarer wire?
I have constant power from the stereo harness so no dramas there. Grounding is from the ground point under the stereo. I've found the green and red/black wires from the door relay under the dash and from the tape I took off them, someone had obviously hooked up something to them before.
Now when I touch a wire from the unit (blue or green/black and brown do it to) to the relay wires, the lock triggers. When I use the remote though the brain clicks but nothing else happens.
I've tried the learning button and the brain clicks from the remote okay but the door stays silent.
The fuse in the unit's power wire is fine.
Is it a combination of wires from the unit I'm supposed to be using? (Like Blue and White etc) If you've got one could you please poke your head in there and tell me which wires you ended up using?
