  Soarer Central * Electrical * High beam problem on my 32 Previous Previous    Next Next
John Stafford
Qld.
Soarer UZZ31 GT-L V8 and a UZZ32 # 514
Reg: 02-2010
Tuesday, November 12, 2013 - 12:48 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I hardly use the high beam as I have a good set of HIDs on the low beam and may just use them to flash and they work fine BUT when I push the right hand wand away from me to actually switch the high beam on permanently, nothing happens.
Help please. Thanks
Katsuji Ueda
Osaka
JZZ30 2.5GT-TL
Reg: 07-2010
Sunday, November 17, 2013 - 08:19 pm, by:  Katsuji Ueda (Senrioka8) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Have you checked the fuse?
UZZ3# models have independent fuses for high beams.
JZZ3# models do not have those independent fuses even though they do have fuse sockets.
John Stafford
Qld.
Reg: 02-2010
Sunday, November 17, 2013 - 10:58 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks for that picture Katsuji,
I have checked both of the fuses and think that the problem was only that my battery was too flat to start the HIDs, only one at a time would work.
I checked the wiring and changed the bulbs and noth worked separately.
It seems my alternator needs doing. I will see tomorrow.
Cheers John
John Stafford
Qld.
Reg: 02-2010
Tuesday, November 19, 2013 - 10:07 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes, my alternator is not charging and my battery was too low to turn both the HID lights on together. I am presently overhauling my alternator.
