  Soarer Central * Electrical * Srs airbag light constantly flashing Previous Previous    Next Next
Shane Hallam
v8
Reg: 02-2014
Monday, March 31, 2014 - 04:27 pm, by:  Shane Hallam (Onelegit) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
G.day all i have searched and researched this problem but cant find anything the same.The problem i have is that the airbag light constantly flashes.All the problems i have seen are of airbag light constantly on not flashing like mine.I have tried the reset wire dance no good still flashes.Diagnosis shows no error AIRBAG OK.The light flashes at a constant rate once every second or so not flashing a code.Hope someone can help me as its driving me nuts.Car is a 91 UZZ31.Any help greatly appreciated.Thanks in advance.Shane.
Monday, March 31, 2014 - 05:56 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Any chance it has been removed? <- wild guess only.
Allan Langford
Reg: 05-2010
Monday, March 31, 2014 - 06:08 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
is the car lowered? could of worn through wires in wheel arch..
Shane Hallam
v8
Reg: 02-2014
Monday, March 31, 2014 - 07:30 pm, by:  Shane Hallam (Onelegit) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Car has been lowered coilovers replaced air bag suspension but not much.I will check tomorrow.i dont think its been removed airbag ecu is there and hooked up.Where are the crash sensors located?Thanks for the quick responses.
Shane Hallam
v8
Reg: 02-2014
Thursday, April 03, 2014 - 12:09 pm, by:  Shane Hallam (Onelegit) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok thought i'd be clever and remove the airbag ecu and replace airbag with nonairbag steering wheel pad.Seemed to work no light no other problems all good patted myself on the back.Put it all back together and now the seats and streering wheel wont move great.
Ray Austin
Soarer GT-TL
Reg: 11-2011
Friday, April 04, 2014 - 12:42 pm, by:  Ray Austin (Rayala) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've got an airbag steering wheel here if you want to try it
Shane Hallam
v8
Reg: 02-2014
Sunday, April 06, 2014 - 09:05 pm, by:  Shane Hallam (Onelegit) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Ray but i have removed the ecu and fitted a non airbag steering wheel pad not going to bother with it.I'm pretty sure that the ecu took a crap.
