Friday, June 20, 2014 - 04:15 pm, by: Andrew Brown(Crazyassdrummerboy)
Hi guys,
Just a little worried what will happen once I get my adaptronic e420c installed in standalone on my v8 soarer.
I want everything electronic-wise to work still after the ECU swap over, including the digital dash. is this going to be an issue, or am I just being a retard?
I should also mention it has been converted to manual so autobox is no longer an issue.
Friday, June 20, 2014 - 10:04 pm, by: Allan Langford(Allan)
what diagrams did you go off?
it should be fine, as long as you fire up the main relay everything should light up, i have not driven mine yet but it ran for 2 hours error free, seems the dash see's no word from the ecu as everything is fine (assumption at it's worst ;) )
Saturday, June 21, 2014 - 01:28 am, by: Andrew Brown(Crazyassdrummerboy)
Loom came with the ecu when I bought it off a guy up in queensland, so I had nothing to do with the loom creation. Ecu was tuned for a 1uz m112 setup funnily enough even though im going htv1900 now its good to know it can support supercharged applications.
so you have an aftermarket ecu which is just running the engine/drivetrain etc?
Sunday, June 22, 2014 - 02:06 pm, by: Ian Rigby(Hiro)
Andrew Brown wrote on Sunday, June 22, 2014 - 11:28 am:
diagnostics as in all of the dash wanings and sensor input for ect, coolant, brakes etc? Or do you mean literally just the diagnostic codes?
The actual ECU error codes - the other run-of-the-mill things such as "alt not charging battery", "rear tail light blown" and "low oil level" katakana etc still work (well, they do with the PowerFC)
Monday, June 23, 2014 - 11:54 am, by: Andrew Brown(Crazyassdrummerboy)
I've gotten in contact with Robbie from wolf and he's pointed me towards the plug n play v550. so no install issues now haha, just need a tune once I get it who actually tunes wolf ECU's? I've never heard of anywhere that does
Saturday, August 09, 2014 - 10:27 pm, by: Cleave Paul(Eiabach)
hi am new hear i have a sc300 with a 1.5jzgte engine in there with a t70 turbo 440cc injectors intercooler kit wide band and an emanage altimate piggy back ecu am looking for a tune for it.hoping that someone did a set up like this and running at list 15psi to 17psi if thats posible.really wish someone could help my email is eiabachsc300@gmail.com thanks in advance}}
