  Soarer Central * Electrical * Full ECU circuit (schmatic) diagram for 1uz-fe Previous Previous    Next Next
Roland Elliott
uzz32 1uz-fe
Reg: 08-2014
Thursday, September 18, 2014 - 11:19 pm, by:  Roland Elliott (Aussie2013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Has any one come across a full Schematic/circuit diagram for the ecu. NOT the pin outs. I have searched all over but no luck.
Matthew Salkeld
1JZ powered 180sx
Reg: 07-2008
Friday, September 19, 2014 - 06:43 am, by:  Matthew Salkeld (Munkymatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There won't be such a document available. Firstly, a circuit diagram would be totally insane (too complicated) and a functional diagram would not provide any useful information. Sometimes other circuits (like ignition, abs, whatever) include some portion of the ECU output stages, but you won't get anything better than that.
Dave Rose
wa
UZZ31 / ML320 CDI
Friday, September 19, 2014 - 11:19 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
not to sure If this is any help?
Max Greenwood
Canterbury
Soarer UZZ31 1UZ-FE
Reg: 10-2012
Friday, September 19, 2014 - 11:41 am, by:  Max Greenwood (Max89) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I came across these if they help.
Roland Elliott
uzz32 1uz-fe
Reg: 08-2014
Friday, September 19, 2014 - 08:36 pm, by:  Roland Elliott (Aussie2013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thank you Matt and Dave, I have those ones, and I will still follow my quest for the circuit diagram, I have been able to source some GMH and Crysler ones in the past no trouble, but this one is elusive and is hiding somewhere.
Matthew Salkeld
1JZ powered 180sx
Reg: 07-2008
Saturday, September 20, 2014 - 08:00 am, by:  Matthew Salkeld (Munkymatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Any chance you could link the GM ones? I'm interested to see them plus it'd help give me a better understanding of what you're looking for.
