Wednesday, February 11, 2015 - 03:26 pm, by: David Haynes(Davessoarer)
i have had problems with the car running good one minute then the next it misses..not firering on all cylinders.. new caps, rotors.leads. plugs. fuel filter..coil pks x2..so after a lot of reading on here i tryed another ecu the same as i have.and it turns over but wont fire..replaced one cap i found bugged..still nothing..do i have to do something else for the ecu to work??
Wednesday, February 11, 2015 - 07:19 pm, by: David Haynes(Davessoarer)
thanks..it not long started on the other ecu..i ran it for about a minutes adjusting the idle control exc..turned it off..started...turned it off left it for an hour now it wont go again..but fires up with old computer.,.ill recap it exc see if that makes any difference.just strange it goes then dosent go .,
