1
3
7
Days
Search
Topics
Tree View
Help
Soarer Central
Electrical
ECT Power/Normal?
Previous
Next
Author
Message
Jan van Berendonk
Reg: 08-2012
Rating: N/A
Votes: 0 (
Vote!
Wednesday, May 27, 2015 - 09:20 pm, by:
Jan van Berendonk
(Janjen)
What does the ECT power/Normal switch do?
Hold the auto in gear longer? Drop the overdrive?
Justin Prewett
Reg: 06-2009
Rating: N/A
Votes: 0 (
Vote!
Wednesday, May 27, 2015 - 09:47 pm, by:
Justin Prewett
(Buzzbox)
It changes the shift pattern. Normal changes sooner, designed to save fuel, whereas power changes higher in the rev range.
Jan van Berendonk
Reg: 08-2012
Rating: N/A
Votes: 0 (
Vote!
Thursday, May 28, 2015 - 09:44 pm, by:
Jan van Berendonk
(Janjen)
So no impact on the engine ECU at all?
Justin Prewett
Reg: 06-2009
Rating: N/A
Votes: 0 (
Vote!
Friday, May 29, 2015 - 10:36 pm, by:
Justin Prewett
(Buzzbox)
The engine ECU controls the auto gearbox and its what will control the shift pattern / changing. The ECT normal / power button will feed back into the engine ECU.
Blake Gloyn
manawatu
soarer JZZ30 TT
Rating: N/A
Votes: 0 (
Vote!
Saturday, May 30, 2015 - 05:30 am, by:
Blake Gloyn
(Blakenz)
the power button does not give the motor any power gains, via timing changes in the ECU, if that is what you are wondering, Jan.
Jan van Berendonk
Reg: 08-2012
Rating: N/A
Votes: 0 (
Vote!
Saturday, May 30, 2015 - 11:49 am, by:
Jan van Berendonk
(Janjen)
So completely irrelevant when converting to a manual gearbox.
Justin Prewett
Reg: 06-2009
Rating: N/A
Votes: 0 (
Vote!
Saturday, May 30, 2015 - 02:58 pm, by:
Justin Prewett
(Buzzbox)
Yep except that you will get ECT errors on the dash (if you have a scroll dash) unless you change the ECU to a manual ECU..
Manual gearbox with auto ECU is possible, will work with errors and i believe there are ways to trick the ECU into thinking the auto is still there.
Manual gearbox is best with manual ECU if its a TT.. not available on the UZZ range.
Scott Vim
Soarer (1uz) Chaser (1jz)
Reg: 12-2010
Rating: N/A
Votes: 0 (
Vote!
Saturday, May 30, 2015 - 08:53 pm, by:
Scott Vim
(1uz1jz)
With a 1uz manual conversion there is no manual ecu. I believe the work around is to make the ecu think it's in neutral.
-Color-
Black
Red
Green
Blue
Yellow
Purple
Orange
Cyan
Gray
White
-Font-
Arial
Courier
Symbol
Times
Verdana
-Size-
Smallest (-2)
Small (-1)
Normal
Large (+1)
Largest (+2)
Username:
Important Posting Information:
Administration
Log Out
Previous
Next
