Blake Gloyn wrote on Thursday, February 09, 2017 - 05:52 pm:
Thursday, February 09, 2017 - 05:52 pm, by: Blake Gloyn (Blakenz) what fuel you running? my original soarer used to falter after about half an hour or so of running on pump 98 ( with 10% ethanol in it) . would run fine on 98, but didn't seem to like the 98 with ethanol.
if the engine electrical system sign came on, then it will have left a code I'm guessing. have YOU run Diagnostics? I'm not talking about their diagnostics machine, I doubt it will pick up anything from an OB1 car.
a failing battery CAN cause a number of issues, so get the battery checked. Doing the fuel pump ECU bypass is a good way of finding out if it is the ECU at fault.
another thing could be faulty caps on the engine ECU. Or a faulty map sensor, or crank angle sensor, or cam angle sensor.
